2005 Bentley GT - Blinker's are not "Clicking/Chiming" when on
Old Feb 20, 2022 | 01:10 PM
Bent's Avatar
Bent is infamous around these parts
I have a 2005 Bentley GT and when I turn the blinkers on, the lights flash, but there is no sound. (The blinker sound isn't working)
I've had people tell me it could be a fuse, also other's said it could be a speaker.
Any suggestions on where I should start?
Any help would be appreciated.
Thanks!
Old Feb 20, 2022 | 08:08 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Thanks!
Hello Bent,
This was Bentleytech's response in 2015 at your request. The owners manual will have a description of each fuse under the steering wheel. First check the three fuses for, ie. turning indicator, door chime and head light chime.
E
Quote: "Drivers Information Panel, there are a total of three fuses located in the dashboard, driver seat kick well, use a flashlite and look under steering wheel, either a release handle for panel to access fuses or just a pull down, just check all fuses if you are not sure which are the ones, good luck."
Old Feb 21, 2022 | 12:41 PM
TeamJones1962's Avatar
Veteran: Navy
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
I thought that was normal. I don’t think I ever heard mines make a sound.
Old Feb 25, 2022 | 04:40 PM
Bent's Avatar
What year is your Bentley and when did you get it?
Old Feb 25, 2022 | 04:42 PM
Bent's Avatar
Originally Posted by 1eapplebaum
Hello Bent,
E
I went under the dashboard, but there are no fuses for the chime. I went through them all, and unfortunately nothing. I'm still searching, if you have any suggestions, they would be greatly appreciated!
Old Feb 25, 2022 | 05:01 PM
Veteran: Navy
2006. A few yr ago
Old Feb 25, 2022 | 05:10 PM
Bent's Avatar
2006. A few yr ago
Very nice, I have a 2005. About 2015, the door chime, blinker chime sounded like it was blown out. Slowly it started getting quieter and quieter before it completely stopped working.
I heard there is a speaker on the board that can be replaced. I just can't locate the board.
I found this picture online, but still unable to locate it in my car
Old Feb 25, 2022 | 06:26 PM
Johnny Hotspur GT's Avatar
Administrator
@Bent ,
That is my picture from the other thread that you responded to, as I said in the other thread, the speaker is located inside the Instrument cluster, you would remove said Instrument cluster from the dash and open it up, the speaker is behind the rear housing of the cluster.
Johnny
Old Feb 25, 2022 | 06:54 PM
Bent's Avatar
@Bent ,
Johnny
https://youtu.be/b4Bxh9HLius
That's what I was looking for!! Thank you very much. Is it easy to remove the instrument cluster?
Tamertimee
Bentley
Mar 29, 2022 11:14 AM
jking702
Bentley
Feb 4, 2022 09:42 PM
2chainz
Bentley
Dec 24, 2021 12:22 PM
hueyy702
Bentley
Nov 16, 2016 09:59 AM
onempty
Bentley
Jan 13, 2015 01:49 PM
