Help with certain fault codes
Old Oct 1, 2022 | 08:03 AM
xclens's Avatar
5 Year Member
xclens is infamous around these parts
Today I did a module by module fault-checking and I cleared every code. Then I did a new automatic fault-checking, and there were a few new codes that I am curious about. I have copied & pasted them below.
Please let me know if there is anything you know about these, or if there is something I should try. I'm all ears.
(I didn't post all fault codes. A lot just said "No Signal/Communication", and I think that just means I do not have those specific features on my car. Like a TV Tuner, convertible top, etc.)
Address 01: Engine Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 DD HW: 07C 906 018 EC
Component: BY-6.0L-TT G ™9409
Revision: --H01--- Serial number: VWZ3Z0G7565217
Coding: 0001175
Shop #: WSC 00083 790 00000
VCID: 6A8DC8F0B06E4B0B597-5160
VINID: 8D34935460E72474C010700100EFB87DA7
2 Faults Found:
001349 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0545 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 70794 km
Time Indication: 0
Freeze Frame:
RPM: 545 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 90.0∞C
Temperature: 46.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 70794 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 93.0∞C
Temperature: 54.0∞C
Voltage: 12.827 V
Readiness: 0110 1101
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 E HW: 5WK 485 07
Component: 6D Kessy 6840
Revision: 68406418 Serial number: VWZ3Z0G7565217
Coding: 0422125
VCID: 290FF7FC75E8801390D-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
6 Faults Found:
01176 - Key
008 - Implausible Signal - Intermittent
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
01334 - Door Control Module; Rear Right (J389)
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
00955 - Key 1
002 - Lower Limit Exceeded
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 B
Component: CM Seat Pass. 0017
Coding: 0000001
Shop #: WSC 06407 109 62589
VCID: 48C95278CEA2591B6F3-5160
8 Faults Found:
002 - Lower Limit Exceeded - Intermittent
02343 - Backrest Locking Switch (E446)
01971 - Adjuster for Seat Heating & Ventilation (E399)
01332 - Door Control Module; Passenger Side (J387)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
01308 - Control Module for Roof Electronics (J528)
01320 - Control Module for Climatronic (J255)
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
3 Faults Found:
009607 - Turbocharger Boost Control Position Sensor 2
P2587 - 008 - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 69996 km
Time Indication: 0
Freeze Frame:
RPM: 1202 /min
Load: 39.6 %
Speed: 0.0 km/h
Temperature: 33.0∞C
Temperature: 33.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 13.335 V
008585 - Bank 2; System too Lean at Idle
P2189 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 70308 km
Time Indication: 0
Freeze Frame:
RPM: 541 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 90.0∞C
Temperature: 21.0∞C
Voltage: 13.589 V
001672 - ECM Power Relay Load Circuit
P0688 - 002 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 70770 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 34.0∞C
Temperature: 27.0∞C
Voltage: 0.000 V
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283 A
Component: 02 Einparkhilfe 0303
Shop #: WSC 00000 000 00000
VCID: 3B233DB48F740283F21-5160
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
End----(Elapsed Time: 07:33, VBatt start/end: 13.8V/13.8V. VIgn 0.0V)------
Old Oct 1, 2022 | 06:28 PM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 70794 km
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 69996 km
Time Indication: 0
Freeze Frame:
RPM: 1202 /min
Load: 39.6 %
Speed: 0.0 km/h
Temperature: 33.0∞C
Temperature: 33.0∞C
Voltage: 13.335 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 70308 km
Time Indication: 0
Freeze Frame:
RPM: 541 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 90.0∞C
Temperature: 21.0∞C
Voltage: 13.589 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 70770 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 34.0∞C
Temperature: 27.0∞C
Voltage: 0.000 V
Hello xclens,
My thougt is to delete the fault codes. Drive a couple days and re scan.
Two notable codes which may return are the turbo position sensor and lean at Idle faults. Drive the car a couple days after the code(s) deletion. A couple short accelerations to run the turbos will aid in this evaluation.
E
Old Oct 1, 2022 | 11:58 PM
xclens's Avatar
5 Year Member
Thank you, I will do so. I'll report back here in a few days!
Old Oct 2, 2022 | 08:26 AM
DesotoJohn's Avatar
DesotoJohn is infamous around these parts
Age and health of battery?
You could have multiple issues resulting in low voltage at several locations, but this would make me question the health of the "house" battery. If your battery is ~4 years or older, then I would replace it before replacing any other components. Good luck!
Old Oct 3, 2022 | 01:44 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
For what it's worth when I had P0546 I had the check engine light on and it proved to be exhaust gas temp sensor bank 1 failure.
Replaced the oxygen temp sensor and the check engine light disappeared.
c0ke
Bentley
43
May 11, 2024 05:44 PM
jc_333
Bentley
Mar 25, 2023 05:06 PM
pupdogg
Bentley
Oct 17, 2021 05:02 PM
Realdeal12
Bentley
14
Jan 26, 2021 06:14 PM
robermj1
Bentley
Feb 16, 2017 11:22 AM
