2008 CFS Brake Pad Sensors
Hey everyone,
I bought
Front Brake Pads : Ferodo # FDB 1001
Rear Brake Pads : Ferodo # FDB 1672
for my 2008 CFS, they did not come with sensors. I thought the fronts were built in.
Does anyone have the VW / Audi parts numbers or comparable to order?
thanks in advance
I bought
thanks in advance
I am sure I can get them, just not sure of the part #
Hello Guys,
On the Bentley brakes, the fronts use a simple disc contact sensor type found on many cars. The rear does not use sensors like these. Instead, when doing a rear brake change the correct way, the thickness (in mm) of the new pads are programmed into the rear brake module, then the computer keeps track of wear and will issue a dash warning when the pads wear to 3mm (I believe memory serves).
I did a writeup on this a few years back and can be read here:
Changing Rear Brake Pads Conti GT - 6SpeedOnline - Porsche Forum and Luxury Car Resource
Hello Guys,
So the rears there is no sensor wire because the brake module is measuring the thickness?
The fronts probably use a standard VW/Audi sensor(s)?
most replacement pads I see on ebay have what almost looks like a builtin sensor to the pad
One thing about looks - You cannot look at a brake pad to determine how it might use sensors on your car because hardly any car has brake systems that are unique to it. Instead, that pad might be used in dozens of other applications, maybe where an old fashioned brake sensor is used and needs the notch. A good example of this is my Aston Martin DB11. I changed rear pads on it and it uses the same brake pad (same Brembo caliper) as used on the 2010 to 2012 Corvette ZR1. No parts places list replacement pads for it (a trick the factory uses to drive business to dealers) but if you know the brake systems, you can get around that kind of nonsense.
Hope it helps,
