Bentley continental gt fans
Old 06-13-2023, 05:41 PM
Johnny Hotspur GT's Avatar
Administrator
@Mitchy1971 ,
I did LHD, I will go double check if there is any difference...
Here are the wiring routes for both fan controller's.
Out of ECU 1 (which should be closest to the windshield) on the larger 81 pin plug, pin # 66 yellow/brown goes straight to fan #1's control module 4 pin plug, on the same ECU #1 but on the 40 pin plug, pin # 104 yellow/brown goes to the 10 pin connector male side as pin # 3, then from the female of this same connection as pin # 3 to the fan # 2 control module 4 pin plug.
The 10 pin male and female connection plug is right in the area of the engine ECU'S.
Both pin #2's on the 4 pin plugs from each fan controller's splice together as you showed, this wire runs to the E fuse box, and is a 10 amp fuse, fuse #12 (F12).
Now I will check my own yellow/brown wires tomorrow, if I have time...
Johnny
Old 06-14-2023, 02:41 PM
Mitchy1971's Avatar
Mitchy1971 is an unknown quantity at this point
Hi Johnny
Thank you for the reply and information on the pin location and numbers
​​​​​​My ecu was the one furthest away from the bulkhead!!
I have just tested them today and all pins 66 and 104 to the 4 pin plugs are 0.1 ohm and all good
The other wire from the fuse 12 is ok and has 12 volts when ignition turned on
Hopefully it's the fans that are faulty and not the ecu fingers crossed
Will update when i get the fans in and tested
All air congaa has been taken out so i cant test until i build it up
Thank you Simon
Old 06-15-2023, 12:56 PM
Mitchy1971's Avatar
Hi.
All wiring ok. New fans fitted today and still have the issue of running all the time. When engine runs they come in and out when air con used but when i switch off they are constantly on
Getting really confused with this fault
Any help is appreciated
Cheers Simon
Old 06-15-2023, 01:23 PM
Mitchy1971's Avatar
Hi again. The 10 amp fuse in the e fuse board is 12 volys when the ignition is turned off. Have to pull fuae to stop fans running
Where does that come from and can i just rum a ignition feed to it instead
Does it go through a relay
Thank you again Simon
Bent
Bentley
08-04-2023 10:34 AM
Shaqovic
Bentley
02-05-2023 01:41 PM
jking702
Bentley
02-04-2022 09:42 PM
onempty
Bentley
01-13-2015 01:49 PM
Quick Reply: Bentley continental gt fans
