Lower control arm bush dimensions
Old Dec 13, 2023 | 05:52 PM
Iain 1250's Avatar
5 Year Member
Iain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud ofIain 1250 has much to be proud of
I'm having a problem with the bushes supplied from the spares place. They came in a kit and are supposed to be 4E0407181B, but when I measure the ones that came out the car, the new ones are smaller, by 0.28m.. They just slide in and will rattle in the arm. I've asked them to measure other bushes they have in stock, to see if these are just out of tolerance ones, but so far had no luck getting them to do it, their solution is to return the kit (I've already fitted all the other bushes so no returning them) and have me to buy the whole control arm. This is the bush that holds the air strut on the front control arm.
If anyone happens to have their old bushes lying around, or a new 4E0407181B bush somewhere, that will help a lot. The new ones are all aluminium, whilst the old ones have a steel core.
These are stock bush for various Audis, might need to see if I can get one from Audi directly is all else fails
Old Dec 18, 2023 | 05:28 PM
Iain 1250's Avatar
5 Year Member
I ended up getting whole new lower control arms, as I could not find a suitable bush that matches what I had in mine. Came to a suitable arrangement with FS which I was happy with.
Old Dec 19, 2023 | 01:44 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
I take it, it was still worth buying the bushings kit to do the rest yourself?
Some of my bushes are showing signs of age so will have to replace at some time
I was hoping to find uprated poly ones.
Old Dec 19, 2023 | 02:03 AM
Iain 1250's Avatar
5 Year Member
I think it is worth it, mine is an early 2005 model, so maybe different to the later ones. The rest of the bushes fitted, I have a 12ton hydraulic press and the a bushing press kit, so made it easy. I priced OEM Audi bushes and they were significantly more expensive than the FS kit, and looked exactly the same.
V12diablo
Bentley
Jul 5, 2022 07:15 PM
FIRST_PORSCHE
Nov 5, 2019 07:38 AM
Yoghurtshotgun
Bentley
Aug 25, 2019 03:59 PM
VAGscum
Jul 20, 2011 08:38 PM
DM1
944 Turbo & Turbo S
Sep 25, 2009 01:09 PM
