Battery Tender
Old Jan 6, 2024 | 08:08 AM
EJag66's Avatar
5 Year Member
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
Battery Tender
If you have issues with your battery tender there might be a quick and innexpensive alternative to a new charger. I use mine regularly and recently began having issues with the unit bringing the batteries to full charge (green light at the end of the charge scale). It would flash on the lowest indication or get stuck halfway through the charge and never finish. Turns out the problem was caused by the MagCode connector, PN M2K211-1AE and available from DigiKey at digikey.com/en/products/detail/rosenberger/M2K211-1AE/19477488?s=N4IgTCBcDaILJgNJgIwoLQoIIFEQF0BfIA. Both male pins are spring loaded to ensure solid connection on the boot, but the + side failed on mine. All you need is a phillips P1 screwdriver to take out three screws. Both connector and wires (at least my wires) are labeled +/- so it is pretty much idiot proof.
Next up: Hood gas strut replacement.
Old Jan 6, 2024 | 10:39 AM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
BTW, it's important to clean the connectors - particularly the one on the car since they can get covered in road grime over time and just a drop of WD-40 will keep the springs working.
JSF721
May 26, 2026 06:37 AM
leftlane
Feb 10, 2026 10:04 AM
7and911
Aug 5, 2014 10:40 AM
93ls1rx7
Oct 29, 2013 08:00 AM
Dr_jitsu
Jan 22, 2012 10:36 PM
