I cant get rid of P2279 ¿Timing chain issues or I'm missing something?
Old Apr 15, 2024 | 03:18 PM
  #31
Jurgeenh Borbon's Avatar
Jurgeenh Borbon is infamous around these parts
Originally Posted by 1eapplebaum
I understand. Pluging the input vacuum line, clearing the codes and than running the engine is to verify if the codes don't return. This will be a confirmation that the overall problem is fixed and all that is requiredis a purge valve.
Before pluging the N80 if you erased the codes in ECU 1 with the vehicle running, as soon the codes were deleted the idle became erratic and the P2279 code appeared immediately, now with the N80 plugged (so no air beign aspirated from there) if you do the same process the idle remain stable and nothing new appear in any ECU, I have to replace this valve and drive the vehicle a few miles.
Old Apr 15, 2024 | 03:34 PM
  #32
As @1eapplebaum stated,
Does the vacuum have pulsation, is the purge valve clicking ?
Johnny
No, the electrical harness is disconnected purposely to test it, the valve should be 100% close with no air passing either way, the gas cap has like a year I bought it new, the jeweled version.
Old Jun 20, 2024 | 11:24 PM
  #33
Is the gas cap tight, as this is all part of the circuit for evap.
Johnny
@Johnny Hotspur GT Yes, fuel cap is tight, I replaced the damaged MAF harness, I replaced the EVAP solenoid, ordered a new PCV so I have both PCV valves genuine and new, all firewall lines are now made out of brass with new check valves on it. All four turbo solenoids on top of the transmission were relocated to a more accessible place and those new hoses smoke tested, no visible smoke leaks in any hose and still getting this god dammed P2279 code with rough idle.
I already checked the rear main seal and seems to be ok, no visible oil leaks and no change on idle if I spray brake cleaner to the weep hole at the bell housing so I can discard this...
I suspect the cause MAY BE the friking conical air pipe that goes from the turbo inlet to the MAF of the bank 1. I see a really small ammount of white smoke comming out where the pipe fits into the turbo elbow, almost imperceptible. The gasket is okay, but the bank 1 pipe seems to be bad designed, doesn't fit correctly, I don't know how to seal this properly, the other side fits perfect and theres no leaks.
¿Any idea how to seal this or what else I can check?
Old Jun 21, 2024 | 08:28 AM
  #34
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
You will need to replace the green "O" ring at the base of the conical pipe to turbo connection. Removing the pipe from the turbo is fidgetty but doable.
90sundevil
924/944/951/968
Mar 22, 2023 05:25 AM
nevaland9
Garage Forum
49
Oct 24, 2012 10:18 AM
Fatandre
BMW //M
Apr 12, 2012 12:09 AM
bbywu
Apr 2, 2011 10:12 PM
racerbvd
911
Jul 17, 2007 06:09 PM
