W12 Crankshaft/Camshaft Loss of Synchronization error code?
Old Jan 8, 2025 | 10:43 AM
981WC's Avatar
981WC is infamous around these parts
The attached error code is coming up on a W12 Bentayga. Anyone encountered this and know if it's serious or can be ignored? The car seems to be working fine and no codes on the instrument panel. This was only discovered when using an OBD reader. Thanks!
Old Jan 10, 2025 | 07:40 AM
981WC's Avatar
Anyone have any idea if I should worry about this? The local Bentley dealer charges $500 just to look at a car, so I wouldn't want to spend that if there's nothing to worry about here. Thanks!
Old Jan 10, 2025 | 08:48 AM
Johnny Hotspur GT's Avatar
Administrator
@981WC ,
I do not know which scanner you are using, but it is not Ross-Tech VCDS or ODIS VAS 5054, therefore you are not giving any fault codes, only a description, have you cleared the faults to see if they return, as to the crankshaft/camshaft loss of synchronization, I would think either the crankshaft position sensor, or one of the camshaft position sensors, but we need more information as to a proper scan to see the actual fault code.
What year is the B, how many miles ?
Johnny
BarryLarge
Bentley
Feb 17, 2024 03:21 PM
tommygunn
Sep 8, 2014 10:02 AM
winnigt2
Jul 17, 2011 08:59 AM
JSmith5690
Jan 17, 2006 09:15 PM
