Pipe location help needed
Old Jun 3, 2025 | 12:24 PM
Shaqovic's Avatar
5 Year Member
Shaqovic is infamous around these parts
Hello guys
i pulled out the engine my self, it was a heck of a job, I changed the broken plastic pipes and assembled the engine back and now I found one plastic tube hanging behind the passenger wheel and I couldn’t locate its place to connect it to.
the part number is 3W1 612 041 AN
attached and pictures of its location, it was connected behind the steering rack marked with red circle and I pulled it out on the floor
Thank you in advance
Old Jun 4, 2025 | 06:18 AM
1eapplebaum's Avatar
5 Year Member
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Originally Posted by Shaqovic
Hello guys
Better pictures please....photograph the whole passenger inner side wheel arch area...there are a couple possible applications for the location of that pipe. More photos are better than less.
Old Jun 4, 2025 | 08:35 AM
Johnny Hotspur GT's Avatar
Administrator
This is what the part number given looks like.
@Shaqovic ,
For clarification and understanding as to location of said vacuum line, please clarify your location of travel, I believe Malta to be RHD, but please state the drive of your Bentley, so we know which side is your passenger side.
Also, which side is your vacuum pump located ?
Johnny
Old Jun 4, 2025 | 12:59 PM
Shaqovic's Avatar
5 Year Member
My car is left hand USA, the pump is located in left side and this pipe is on the other side (passenger) right side
Old Jun 5, 2025 | 08:25 AM
Shaqovic's Avatar
5 Year Member
Btw my car is 2005 and the sticker on the pipe has 2014 on it!
could someone help otherwise I am going to drop the engine down again
Old Jun 8, 2025 | 09:50 AM
Shaqovic's Avatar
5 Year Member
I dropped the engine down again and I need to know where to connect these pipes to asap please
@Johnny Hotspur GT
Old Jun 8, 2025 | 02:01 PM
Shaqovic's Avatar
5 Year Member
I guess the pipe in the first image and the last image goes together, correct me if I’m wrong but the one attached with the canister I couldn’t find it’s partner.
i am in a hurry and all help is appreciated
Old Jun 8, 2025 | 02:16 PM
Administrator
Hello @Shaqovic ,
To start, please tell us, is this your original engine, with original turbos, therefore nothing changed, nothing from different years, etc.
As to your last picture, please clarify which line you are pointing to, I take it maybe your middle finger pointing to the black line going through the small hole ?
As I see it, it appears that your rubber line with the curved metal tube, that I have marked with purple dots, that appears that you have pulled the tube out of the turbo, depending on year, some use all 3 holes, whereas some cap one, that's why I need to know exactly what we are working with, if all original, please post a picture of the turbo top where the other tubes/hoses are.
I will continue in my next post as to the hose with the braided cover.
Johnny
Old Jun 8, 2025 | 02:26 PM
Administrator
@Shaqovic
Like this, 3 lines at turbo.
Johnny
Old Jun 8, 2025 | 02:57 PM
Administrator
@Shaqovic ,
As to the hose with the braided cover, I have marked that in green, and yes, it should hook up to the black plastic vacuum line in the passenger wheel well, my only issue is the fact of the black plastic tube running through that small hole, mine was not like that, my vacuum tube runs right with the 3 other tubes, meaning, the fuel supply, fuel return, and the purge, the blue, white, and black lines with the quick connection fittings.
See my pics, my vacuum line runs with the other 3 through a rectangular opening, not a single small hole.
Johnny
Old Jun 8, 2025 | 05:25 PM
Shaqovic's Avatar
5 Year Member
@Shaqovic ,
Johnny
I was suspicious about it and you confirmed it, they goes together, now with the third pipe which has a metal end in it, I checked the drivers side and it’s capped but the passenger side is not, my main problem was the broken vacuum lines that’s why I dropped the engine, I need to dissemble the turbo and hope I will find it, I have this car for 10 years now, I don’t think the engine is changed.
Old Jun 8, 2025 | 05:45 PM
Shaqovic's Avatar
5 Year Member
If I couldn’t find its place in the turbo, could I just cap it and no harm will happen, perhaps the previous owner replaced the turbo which I doubt it happened, the pipe comes from the throttle to canister (emission purge) what purpose it serves to connect it to the turbo ?
Old Jun 8, 2025 | 05:47 PM
Administrator
@Shaqovic ,
Ok, the driver's side is capped, post a picture of the passenger side turbo at the location on top, you shouldn't need to disassemble the turbo, just press the tube back into the open hole, it's on the vacuum side, so no pressure to blow it out.
Please post a picture, I know it's 1:46 AM for you, but as I understood your PM, you are working through it right now.
So, move the plastic bag and snap some pictures please.
Johnny
Old Jun 8, 2025 | 06:00 PM
Shaqovic's Avatar
5 Year Member
@Shaqovic ,
Johnny
the car is in the garage shop now and I’m sitting home on the forum looking for answers
I will do as instructed tomorrow morning, your help relieved me a lot
Old Jun 8, 2025 | 06:12 PM
Administrator
@Shaqovic ,
Great, get some rest and start fresh !
The first pictures are of the 2 turbos I have sitting upstairs right now, I just snapped these pictures, the driver's side is capped, the passenger side is missing the tube just as I am 99.975% yours is, my belief is that your tube came out just as it did on the set I have, I have also added 2 pictures showing the tube in place.
Good luck tomorrow !
My turbos.
Driver's side and passenger side turbos from the internet showing the driver's side capped, and the tube installed on the passenger side.
Johnny
