Lowering links
Old Sep 4, 2007 | 11:40 AM
*STATUS*'s Avatar
*STATUS* is infamous around these parts
Originally Posted by jgraham
Neil, nice job, car looks great. Can't beat the price, do not see the need for the electronic module. You can also raise the car still with button on the consol.
Enjoy.
John.
the renn-tech module is definately worth the money if you were to go with that particular module. you can slam your car or go up to stock or anywhere in between that makes you feel comfortable and i believe can do damping rates as well or something like sport and comfort
Old Sep 4, 2007 | 12:53 PM
Paldi's Avatar
Paldi is infamous around these parts
All I really want is an off/on switch in the cockpit! I need to lower the car when it's parked and raise it to stock height when I start the motor and drive off. It would be OK if it raised up automatically, but I want to be able to order it to "drop" by pushing a button.
Old Sep 4, 2007 | 02:20 PM
*STATUS*'s Avatar
that can easily be done... hit up Jon Pek @ jonari tell him chris with EC sent you he will hook you up and help you with anything you need
www.jonari.com
Old Sep 4, 2007 | 05:04 PM
Paldi's Avatar
Email sent to jon, thanks!
Old Sep 4, 2007 | 08:52 PM
jgraham's Avatar
jgraham is infamous around these parts
I wanted to lower my Bentley, paid $250 for links, do not think it is worth spending $2500 for a module!
Old Sep 6, 2007 | 12:59 AM
Neilkf's Avatar
Neilkf is infamous around these parts
I agree. The modules I've seen will only allow a maximum of around 40mm drop. After that I expect there are geometry issues to deal with.
Also, I wouldn't fancy your chances of a friendly reception for any warranty issues if the repairer found evidence of a non-standard electronic gizmo being installed in your car.
The links however will just pop off and you can put the originals back on - no one's the wiser.
Old Sep 6, 2007 | 01:35 AM
*STATUS*'s Avatar
Yeh but with the links you cant get maximum raising and lowering when you want and links in the long run are bad for your car, IM not positivie but i believe it is the renntech module u can pull out and its like it was never there. and the renntech i think might be less that 2500.and with the right module u can get maximum height or maximum "droppage" when desired.
Old Sep 6, 2007 | 05:48 PM
djenders's Avatar
djenders has a spectacular aura aboutdjenders has a spectacular aura about
I just ordered a set for my Bentley. Thanks for the info.
here is the link to my car. same color.
I had it lowered before. But had to change it back for a short time. But these links seem better then what I had before.
Old Sep 6, 2007 | 06:12 PM
*STATUS*'s Avatar
Do you have pictures
Old Sep 6, 2007 | 06:44 PM
djenders's Avatar
Old Sep 6, 2007 | 11:51 PM
*STATUS*'s Avatar
looks pretty good man
Old Sep 7, 2007 | 12:18 AM
Neilkf's Avatar
Nice. Any idea what the actual drop is?
Old Sep 7, 2007 | 12:23 AM
*STATUS*'s Avatar
I think thats determined by you i think max drop is 2 and sum change
Old Sep 7, 2007 | 12:56 AM
Neilkf's Avatar
I mean the actual drop on the blue car shown in the link
Old Sep 7, 2007 | 01:02 AM
*STATUS*'s Avatar
no clue man but its a pretty substantial drop
