E46 M3 or 996?
Old Feb 1, 2008 | 09:28 AM
czechchamp's Avatar
czechchamp has a spectacular aura aboutczechchamp has a spectacular aura aboutczechchamp has a spectacular aura about
If you can, get the 996TT.
Old Feb 1, 2008 | 10:21 AM
John814's Avatar
John814 is infamous around these parts
Approx. how much should I allocate annually for maintenance for the E46 M3 or 996TT? I have seen figures for F-cars, listing a disposable amount of income in case of something going wrong plus reg. maint. fees, but what about the 996TT or E46?
Thanks for the input and help guys!
Old Feb 1, 2008 | 12:21 PM
InfamousD's Avatar
Formerly 04ImolaZHP
InfamousD is infamous around these parts
Originally Posted by Dr_jitsu
For a dd hard to beat the M3...but you already have a daily. Get a 996TT and mod it. Best bang for the buck fast car hands down, right now. Trying to make an M3 really fast (guy who built my M3 spent over 100K) is expensive.
agreed.
if you didint have a DD that you were thinking of keeping, my response would have been different.
Old Feb 1, 2008 | 03:58 PM
stuntman's Avatar
stuntman is a name known to allstuntman is a name known to allstuntman is a name known to allstuntman is a name known to allstuntman is a name known to allstuntman is a name known to all
996 911 vs. E46 M3 = E46 M3 gets my vote. More practical, can carry more people and stuff, and much more neutral car. Plus is a lot more fun to slide around...
Old Feb 1, 2008 | 05:04 PM
epbrown01's Avatar
epbrown01 is infamous around these parts
Like pulling teeth, isn't it? I think you've asked the same question 3 times, phrased differently, with no real response.
Going between the 2 cars you've decided on, I'd pick the Porsche 996. The original purpose of the M3 was to be a compromise for the person that wanted a sports car but needed a daily driver. As you've already got a daily driver, there's no need to settle for the compromises of the M3.
That said, running costs will depend somewhat on how you buy and how much you drive. An E46 M3 can still be found under factory warranty, which means you can get another couple of years of free maintenance. With a CPO and extended service warranty, you could be covered until 100k miles with almost no out-of-pocket expenses after you buy.
If you get a car that doesn't have either: the S54 engine gets an Inspection One ever 15k miles and an Inspection Two every 30k. The One is ~$500, the Two ~$2000+ depending on labor charges, and includes a valve adjustment. Personally, I'd recommend changing the oil at least once mid-interval (every 7500 miles) which should be $100 or so if you do it yourself. how long the clutch, brakes, and tires last depends on your driving style.
Hopefully a Porsche owner will chime in with hard numbers on the 996's running costs.
Old Feb 2, 2008 | 11:29 AM
John814's Avatar
Thanks for not dodging my question!
I tried searching for all this before, but didn't have too much luck. The BMW/Porsche "fun car" proabably won't get driven more than 5-10k miles a year, but it's hard to say. So those service intervals shouldn't be too bad.
I'll probably try searching again later tonight or maybe post something in the 996TT Area about operating costs, specifically the breakdown of each service.
Thanks again
Old Feb 2, 2008 | 12:12 PM
InfamousD's Avatar
Formerly 04ImolaZHP
clutch on a 2005 911 was in the $2k range (closer to $3k i think), i forget how much exactly. oil at the dealer is about $200+ vs. low $100's for the m3. breaks, and all the other things are covered under the new BMW policy and you can extend that maintenance plan another 2 years 50k miles for i believe around $1,500. but from what i remember the breaks on the porsche were significantly more expensive than on the m3.
before i bought my m3 i did some math comparisons between it and the boxster S and i figured with as much as i drive, the boxster S was gonna cost me (from what i remember) a couple of $k more a year. so figure theh 996 will probably cost a little more than that yet. not a make it or break it difference, but you will be spending thousands more on a 911 than you would on an m3. of course this assumes you dont have any "major" fialures and similar type problems.
Old Feb 2, 2008 | 01:05 PM
evo911's Avatar
evo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the rough
996 for sure
Old Feb 2, 2008 | 06:40 PM
epbrown01's Avatar
I used that rationale when buying my M Coupe, which has similar service requirements to the E46 M3. I know from my previous Z4 that I drive about 5000 miles/year in my fun car, which means the expensive Service Two is spread out at 6 year intervals, making it pretty cheap to run down the line.
The real trick is avoiding upgrades. My 911SC was about $1500/year to run as a daily driver, but I spent twice that on aftermarket stuff seen hanging around on Porsche forums. The Z4MC will cost me $8k this year in aftermarket upgrades, though that should taper off sharply next year.
Old Feb 2, 2008 | 07:24 PM
Boxzing's Avatar
Boxzing is infamous around these parts
if you can't afford the 996TT get a 996 C4S, sweet widebody look. rarer than the M3 as well.
Old Feb 3, 2008 | 06:46 PM
silvershark's Avatar
silvershark is infamous around these parts
Video Which One
Go with the 996TT, you will not be disappointed.
Old Feb 11, 2008 | 10:13 AM
M BADGER's Avatar
M BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud ofM BADGER has much to be proud of
I prefer the M3 to the base 996.
I think about getting rid of my M3 for a 996 TT or GT3, but not a base 996.
Old Feb 11, 2008 | 10:27 AM
Cannonball996's Avatar
Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !
I have had both as well, I would recomend the 996, I really have not had any maintenence issues with my 996 and everything has held together on it. the BMW had all kinds of issues, little things would come appart in the interior, the car over heated once that was a $$$ job.
Old Feb 17, 2008 | 01:35 AM
kcphuah's Avatar
kcphuah is infamous around these partskcphuah is infamous around these parts
911 TT no questions asked if you are not looking for a DD. Why do I say that? because I have them both.
Old Feb 17, 2008 | 07:57 AM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
Now are we talking about a 996 TT or 996(Carrera S)?
Big difference. 996TT >>> M3; 996 > M3.
Handling and breaks are better.
The above based on IMO.
