Seatbelt is destroying door trim in e90
Old Feb 7, 2008 | 12:51 PM
rriva's Avatar
rriva is infamous around these parts
Originally Posted by ajs887
You can seriously get this changed under warranty? I didn't know that. The same thing's been happening to my trim. It started to bother me, but then I just stopped caring. I'm going to look into this.
I have an offer to change it out at my dealer, but only after some complaining. Let us know if you are successful. Others have tried and failed..
Old Feb 7, 2008 | 02:20 PM
Trill M3's Avatar
Trill M3 is infamous around these partsTrill M3 is infamous around these parts
Yes you can seriously get this changed out under warranty. I 've had mine done before. I need to have it done again.
Old Feb 7, 2008 | 02:22 PM
JoeyG's Avatar
JoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud of
Trill, If I send my trim pieces to your dealer, will they replace them?
Joe
Old Feb 7, 2008 | 02:29 PM
Trill M3's Avatar
Joe
Joe,
My dealer will replace it under warranty if you bring the vehicle in. I had to bring my vehicle in to have it loked at. Mine was pitting all over. No way to deny it!
Naseem-
Old Feb 7, 2008 | 03:37 PM
rooster3.0's Avatar
rooster3.0 is infamous around these parts
There is a slider on the belt that prevents this. You simply have to slide it up so it sit's right underneath the buckle. This way when you let go of the belt, the buckle gets raised up instead of banging in to the trim. It only took two pits in my aluminum to figure this out.
Old Feb 7, 2008 | 08:59 PM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
same thing happed when i had my 330ci
Old Feb 7, 2008 | 09:11 PM
WearyMicrobe's Avatar
WearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond reputeWearyMicrobe has a reputation beyond repute
Boss has had his changed out once at ~14K on the clock.
NC 996TT
Mar 23, 2023 06:19 AM
Axxlrod
Oct 26, 2015 11:54 AM
simoncpw
Sep 8, 2015 10:55 PM
AM v12v
Sep 7, 2015 02:17 PM
