BMW Spec E30 Race Car Custom Work by G Rides
Old Jan 21, 2010 | 08:47 PM
Gary@G Rides's Avatar
Gary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond reputeGary@G Rides has a reputation beyond repute
This BMW was brought to G Rides for a few projects.
Project 1 was to mount a battery more securely in the stock location.
Old Battery, held in by some hooks attached to a plastic battery tray. Not much room for more, the metal hooks just fit next to the battery, tight space.
Decided to go with an Optima Red Top, a new battery box and tray. Found a nice battery box that would fit in the tight space. Built a metal tray to be used as a base for the battery box, required metal cutting, bending, welding, some measuring, etc. The battery box and the new tray we fabricated are well bolted together, the design of the base of the battery box did not lend itself to welding.
This new set-up bolts into factory mount points.
Project 2 was to build jack points in the center of the car. This was done with angle iron sandwiching the sheet metal seem and through bolted. This car was getting jacked up just on the sheet metal seem which had rolled over the seem and just needed more strength. The Seem was bent back then the angle iron was added, it's strong now.
Project 3 was to add some strength to the exhaust as it's only attached towards the front and back, no real support in the center. We bent, drilled a metal strap bolting (included some rubber isolators to allow exhaust to still wiggle as needed) it to a couple of factory mounting holes. Bottom of strap was welded to the exhaust.
Project 4 was to mount the 3rd brake light and wire it in. We made this bracket from scratch, bolted in the light and wired it.
Off to the races.
Old Jan 23, 2010 | 06:54 PM
UMADBRO's Avatar
UMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond reputeUMADBRO has a reputation beyond repute
old school!
Old Jan 23, 2010 | 10:36 PM
Devin1205's Avatar
Devin1205 is infamous around these parts
e30's are great little cars to mess with and so many shops have them for cheap racers. is everything else about this car pretty much stock like motor and brakes?
Old Jan 25, 2010 | 09:06 AM
Engine is stock, no internal mods are allowed, the guys with the most hp tend to be the ones with the freshest motor. Brakes I believe are stock calipers and you can play with pads and fluid. These guys have a lot of fun.
Old Jan 26, 2010 | 04:00 PM
ALPINE6SPD's Avatar
ALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant futureALPINE6SPD has a brilliant future
That is so sick. I would take off the old Mopar roadrunner sticker though.
Old Feb 7, 2010 | 03:11 AM
Roland H.'s Avatar
Roland H. has a spectacular aura aboutRoland H. has a spectacular aura about
E30 Racecar towed by a Porsche SUV. Epic.
Perkman87
Nov 19, 2015 05:31 PM
Aug 21, 2015 06:34 AM
albert@velosdesignwerks
BMW //M
Aug 20, 2015 07:12 AM
pwdrhound
Aug 20, 2015 05:54 AM
