How to remove front seats from '05 545
Old Jan 14, 2006 | 10:52 PM
bigsky's Avatar
bigsky is infamous around these parts
Has anyone removed or know how to remove the front seats from a 2005 545? Will it trigger any airbag or other warning lights?
Old Jan 15, 2006 | 04:26 PM
TraderHal's Avatar
TraderHal is a glorious beacon of lightTraderHal is a glorious beacon of lightTraderHal is a glorious beacon of lightTraderHal is a glorious beacon of lightTraderHal is a glorious beacon of light
you may get a better response from the bmw boards fwiw.
forums.bimmerforums.com
http://www.m5board.com
Old Jan 16, 2006 | 10:03 AM
Tracktoy's Avatar
Tracktoy is infamous around these parts
I'm no expert but I believe by disconnecting the battery and the removing the seats could avoid an airbag light or worse yet deployment. Just hook everything back up and double check before going hot with the 12V.
Old Jan 16, 2006 | 10:17 AM
BBGT2's Avatar
BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !BBGT2 Is a GOD !
If you disconnect the battery wait at least 5 minutes before disconnecting anythin to do with an air bag system. It has a diode that is still energized after voltage drop and it could trigger flase codes.
FWIW
Bajo
PS. Make sure you have the seat correctly positioned in order to get to all the mounting bolts as you will not be able to move the seat after you disconnected the battery but you knew that already.
Old Jan 16, 2006 | 10:14 PM
bigsky's Avatar
Thanks everyone for your posts
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
MurderedTurbo
Aug 28, 2015 09:06 AM
