New M3 vs "Proceded 335"
Old Apr 14, 2007 | 03:51 AM
Fanman's Avatar
Fanman is infamous around these parts
Originally Posted by M3Tifosi
from the trq numbers it seems like the 335 would be alot quicker out of the block.
Not really. It does not have an LSD like the M3, not to mention it will be on narrower tires (255 vs. 265's, not to mention the stock run flats on the 335i are a joke) and will be slightly heavier. All that leads to M3 from a dig, and from a roll on where LSD's & weight become less of a factor then the chipped 335i's will have a much better acceleration range given it's massive torque advantage (you push the accelerator it goes).
Old Apr 14, 2007 | 05:37 AM
eMJay1133's Avatar
eMJay1133 is infamous around these partseMJay1133 is infamous around these parts
When is someone gonna build the 335 engine and slap some huge turbos on it?
Old Apr 14, 2007 | 11:54 AM
335_II's Avatar
335_II is infamous around these parts
thats what i want to see!
Old Apr 14, 2007 | 03:05 PM
unvmy996's Avatar
LMAO all u 335 guys are too funny ....all of the sudden u think u have god by the *****..... stock for stock with witha e46 m3 . it was basicly a drivers race .. with the sligh edge to the m3 up high .....
the new m3 will a$$ rape the 335 ... bad ..
Old Apr 14, 2007 | 03:13 PM
InfamousD's Avatar
Formerly 04ImolaZHP
InfamousD is infamous around these parts
you are probably right about stock for stock. but this thread isnt about stock for stock...
eMJay1133's Avatar
Yeah that would be awesome!
Old Apr 14, 2007 | 04:08 PM
Fanman's Avatar
You did read the part about "Proced'ed/chipped" 335i right. I'm sure an upcoming M3 will crush a STOCK 335i, but add another +60 hp, and +100 lb.-ft. tq. and it very well can be a different story.
Old Apr 14, 2007 | 04:45 PM
Raz5219's Avatar
Raz5219 is a name known to allRaz5219 is a name known to allRaz5219 is a name known to allRaz5219 is a name known to allRaz5219 is a name known to allRaz5219 is a name known to all
I honestly think that because of the torque advantage, the 335 will take the M from a dig (even without LSD), but then the M will catch up past 80mph and slowly pass the 335. Stock M's feel very docile at lower RPM's. The 335 doesn't feel like that because of the torque available at low RPM's. This makes for more fun daily driving. It's hard to wind a car out to higher RPM's when commuting to work everyday..especially here in NY!
Old Apr 16, 2007 | 01:26 AM
TTony's Avatar
TTony is infamous around these partsTTony is infamous around these parts
I doubt this very much. Without drag radials, the 335's are not getting sub 2 sec 60' times even when chipped. The M3 should do the 1/4 in the mid 12's and probably trap in the 112-114mph range. I bet it will pull a chipped 335 from a dig and a roll. But... just get bigger turbo's.
Old Apr 16, 2007 | 09:07 AM
335_II's Avatar
A 335 with active autowerek exhaust and ECU ran a 12.6 at moroso on radials
Old Apr 16, 2007 | 11:08 AM
TTony's Avatar
Are referring to this run? http://www.dragtimes.com/BMW-335i-Timeslip-11392.html
Note the "Tires: DR" and they got a 1.849 60' time. I assume DR is Drag Radials and not Dunlop Radials?
Old Apr 16, 2007 | 04:14 PM
onetwo's Avatar
onetwo is infamous around these parts
Torque numbers mean very little in these comparisons. Torque only tells you the degree of force that can be delivered at a specific instant (not important) while horsepower measures the actual amount of work that can be done by an engine over a period of time (important). I predict that the new M with "only" 295 ft-lbs of torque will manage to walk away from a chipped 400 ft-lbs torque 335i.
Old Apr 16, 2007 | 07:52 PM
335_II's Avatar
deffinatley will be intresting to see
Old Apr 16, 2007 | 09:25 PM
PorscheC4's Avatar
PorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant futurePorscheC4 has a brilliant future
you are forgeting one key piece of info here. yea the e92 m3 has 414 bhp and 295 lb/ft of tq, but that 400 lb ft of tq 335 will be pushing around 400 hp as well, so thats important to take inot consideration.
Old Apr 17, 2007 | 02:18 AM
JNRSM3's Avatar
JNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to allJNRSM3 is a name known to all
only time will tell, I guess. I have had my 335 for a week now and I love it. I definately can see alot of upside although I see the 335 more more as a "daily driver" type than an M3. It balances well the need for convenience, sportiness, power and handling.
