:: ECS Tuning :: Schwaben Rocker Panel Jack Pad for BMW
We decided to take a good thing and make it better. Our trusty BMW jack pad adapter has been a longstanding favorite with BMW owners who like to jack their cars safely and easily. Our newly upgraded BMW jack pad adapter builds on the success of the old one, with added features that make it stronger, more durable, and even easier to use. Full-seam welded for added strength, the new adapter is black zinc coated to resist rust, with a revised insertion end that slides into the jack port with less effort. Its longer length places the jack head farther from the body for added safety.
Click HERE for your E36 Rocker Jack Pad Adapter
Click HERE for your E31 Rocker Jack Pad Adapter
Click HERE for your E38 Rocker Jack Pad Adapter
Ok so I made a claim that our Schwaben Jack Pad Adapter is the best.... and I've had a TON of PMs asking why. So here's why
Our Schwaben adapter has a long shaft to position jack plate away from the body for adequate jack clearance.
Our Schwaben adapter is heat treated 4140 high strength steel.
Our Schwaben adapter has a fully seam welded 70mm jacking plate.
Our Schwaben adapters exact-fit profile limits the movement in use keeping you safer.
Our Schwaben adapter is black zinc coated for corrosion resistance.
The proof is in the make up. You've had the rest, now here is the best.
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
