:: ECS Tuning :: South Bend Clutch Kits|So Clutch
Tired of a slipping clutch?
South Bend it.
Click HERE for your E30 325i/is/xi South Bend Stage 1 Heavy Duty Clutch Kit
-Conservatively Rated at 260 ft/lbs-
Click HERE for your E30 325i/is/xi South Bend Stage 2 Daily Clutch Kit
-Conservatively Rated at 285 ft/lbs-
Click HERE for your E30 325i/is/xi South Bend Stage 2 Drag/Drift Clutch Kit
-Conservatively Rated at 370 ft/lbs-
Click HERE for your E30 325i/is/xi South Bend Stage 2 Endurance Clutch Kit
-Conservatively Rated at 355 ft/lbs-
Click HERE for your E30 325i/is/xi South Bend Stage 3 Daily Clutch Kit
-Conservatively Rated at 400 ft/lbs-
Click HERE for your E30 325i/is/xi South Bend Stage 3 Drag/Drift Clutch Kit
-Conservatively Rated at 500 ft/lbs-
Click HERE for your E30 325i/is/xi South Bend Stage 3 Endurance Clutch Kit
-Conservatively Rated at 430 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 1 Heavy Duty Clutch Kit
-Conservatively Rated at 295 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 2 Daily Clutch Kit
-Conservatively Rated at 315 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 2 Drag/Drift Clutch Kit
-Conservatively Rated at 420 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 2 Endurance Clutch Kit
-Conservatively Rated at 385 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 3 Daily Clutch Kit
-Conservatively Rated at 495 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 3 Drag/Drift Clutch Kit
-Conservatively Rated at 650 ft/lbs-
Click HERE for your Z3 3.0i (2001-2002) South Bend Stage 3 Endurance Clutch Kit
-Conservatively Rated at 550 ft/lbs-
Click HERE for your E46 325xi (2001-2005) South Bend Stage 1 Heavy Duty Clutch Kit
Click HERE for your E46 325xi (2001-2005) South Bend Stage 2 Daily Clutch Kit
Click HERE for your E46 325xi (2001-2005) South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your E46 325xi (2001-2005) South Bend Stage 2 Endurance Clutch Kit
Click HERE for your E46 325xi (2001-2005) South Bend Stage 3 Daily Clutch Kit
Click HERE for your E46 325xi (2001-2005) South Bend Stage Drag/Drift Clutch Kit
Click HERE for your E46 325xi (2001-2005) South Bend Stage Endurance Clutch Kit
Click HERE for your E36 318i/Is/Ic/Ti South Bend Stage 1 Heavy Duty Clutch Kit
-Conservatively Rated at 280 ft/lbs-
Click HERE for your E36 318i/Is/Ic/Ti South Bend Stage 2 Daily Clutch Kit
Click HERE for your E9X 335i South Bend Stage 2 Daily Clutch Kits
-Conservatively Rated at 425 ft/lbs-
Click HERE for your E9X 335i South Bend Stage 2 Drag/Drift Clutch Kits
-Conservatively Rated at 525 ft/lbs-
Click HERE for your E9X 335i South Bend Stage 2 Endurance Clutch Kits
-Conservatively Rated at 490 ft/lbs-
Click HERE for your E9X 335i South Bend Stage 3 Daily Clutch Kits
Click HERE for your E9X 335i South Bend Stage 3 Drag/Drift Clutch Kits
Click HERE for your E9X 335i South Bend Stage 3 Endurance Clutch Kits
-Conservatively Rated at 535 ft/lbs-
Click HERE for your E39 525i South Bend Stage 1 Heavy Duty Clutch Kits
Click HERE for your E39 525i South Bend Stage 2 Daily Clutch Kits
Click HERE for your E39 525i South Bend Stage 2 Drag/Drift Clutch Kits
-Conservatively Rated at 450 ft/lbs-
Click HERE for your E39 525i South Bend Stage 3 Daily Clutch Kits
Click HERE for your E39 525i South Bend Stage 3 Drag/Drift Clutch Kits
Click HERE for your E39 525i South Bend Stage 3 Endurance Clutch Kits
Click HERE for your E46 M3 South Bend Stage 1 Heavy Duty Clutch Kits
Click HERE for your E46 M3 South Bend Stage 2 Daily Clutch Kits
-Conservatively Rated at 340 ft/lbs-
Click HERE for your E46 M3 South Bend Stage 2 Drag/Drift Clutch Kits
Click HERE for your E46 M3 South Bend Stage 2 Endurance Clutch Kits
Click HERE for your E46 M3 South Bend Stage 3 Daily Clutch Kits
Click HERE for your E46 M3 South Bend Stage 3 Drag/Drift Clutch Kits
-Conservatively Rated at 600 ft/lbs-
Click HERE for your E46 M3 South Bend Stage 3 Endurance Clutch Kits
Click HERE for your E46 M3 Clutch Install Kit
Click HERE for your E60 535i N54 (2008-2010) South Bend Stage 2 Daily Clutch Kit
Click HERE for your E60 535i N54 (2008-2010) South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your E60 535i N54 (2008-2010) South Bend Stage 2 Endurance Clutch Kit
Click HERE for your E60 535i N54 (2008-2010) South Bend Stage 3 Daily Clutch Kit
Click HERE for your E60 535i N54 (2008-2010) South Bend Stage 3 Drag/Drift Clutch Kit
Click HERE for your E60 535i N54 (2008-2010) South Bend Stage 3 Endurance Clutch Kit
Click HERE for your E82/88 135i N54 2008-2010 South Bend Stage 2 Daily Clutch Kit
Click HERE for your E82/88 135i N54 2008-2010 South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your E82/88 135i N54 2008-2010 South Bend Stage 2 Endurance Clutch Kit
Click HERE for your E82/88 135i N54 2008-2010 South Bend Stage 3 Daily Clutch Kit
Click HERE for your E82/88 135i N54 2008-2010 South Bend Stage 3 Drag/Drift Clutch Kit
Click HERE for your E82/88 135i N54 2008-2010 South Bend Stage 3 Endurance Clutch Kit
Click HERE for your BMW E39 M5 South Bend Stage 1 Heavy Duty Clutch Kit
Click HERE for your BMW E39 M5 South Bend Stage 2 Daily Clutch Kit
-Conservatively Rated at 440 ft/lbs-
Click HERE for your BMW E39 M5 South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your BMW E39 M5 South Bend Stage 2 Endurance Clutch Kit
Click HERE for your BMW E39 M5 South Bend Stage 3 Daily Clutch Kit
Click HERE for your BMW E39 M5 South Bend Stage 3 Drag/Drift Clutch Kit
-Conservatively Rated at 700 ft/lbs-
Click HERE for your BMW E39 M5 South Bend Stage 3 Endurance Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 1 Heavy Duty Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 2 Daily Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 2 Endurance Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 3 Daily Clutch Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 3 Drag/Dift Clutch Kit
Click HERE for your BMW E39 530i South Bend Stage 3 Endurance Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 1 Heavy Duty Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 2 Daily Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 2 Endurance Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 3 Daily Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 3 Drag/Drift Clutch Kit
Click HERE for your BMW E46 323i (1999-2000)/E46 323ci (2000) South Bend Stage 3 Endurance Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 1 Heavy Duty Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 2 Daily Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 2 Endurance Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 3 Daily Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 3 Drag/Drift Clutch Kit
Click HERE for your E46 325i (2001-2005) / E46 325ci (2001-2006) South Bend Stage 3 Endurance Clutch Kit
Click HERE for your BMW Z3 M S52 (1998-2000) South Bend Stage 1 Heavy Duty Clutch Kit
For use with dual mass flywheels
Click HERE for your BMW Z3 M S52 (1998-2000) South Bend Stage 2 Daily Clutch Kit
-Conservatively Rated at 330 ft/lbs-
Click HERE for your BMW Z3 M S52 (1998-2000) South Bend Stage 2 Endurance Clutch Kit
Click HERE for your BMW Z3 M S52 (1998-2000) South Bend Stage 3 Daily Clutch Kit
Click HERE for your BMW Z3 M S52 (1998-2000) South Bend Stage 3 Endurance Clutch Kit
For use with single mass flywheels
Click HERE for your E36 328i South Bend Stage 1 Heavy Duty Clutch Kit
Click HERE for your E36 328i South Bend Stage 2 Daily Clutch Kit
Click HERE for your E36 328i South Bend Stage 2 Drag/Drift Clutch Kit
Click HERE for your E36 328i South Bend Stage 2 Endurance Clutch Kit
Click HERE for your E36 328i South Bend Stage 3 Daily Clutch Kit
Click HERE for your E36 328i South Bend Stage 3 Drag/Drift Clutch Kit
Click HERE for your E36 328i South Bend Stage 3 Endurance Clutch Kit
