:: ECS Tuning :: N54 Fuel Injector Kits|The Cure
Subscribe
Jul 16, 2014 | 03:01 PM
The N54 straight-six engine has earned several awards for engineering excellence; partly through novel turbocharging and advanced variable valve timing, but crucially, through second-generation piezo direct injection.
This fuel injection technology relies upon the expansion of crystalline materials under the influence of electricity to inject fuel to exceedingly close specifications for superior control over spray characteristics.
ECS assembled and genuine OEM Injector Replacement Kits restore your engine's brilliance by taking care of the entire system in one servicing.
Click HERE for your N54 Fuel Injector Replacement Kit
Click HERE for your N54 Fuel Injector Installation Kit
Click HERE for a single N54 Fuel Injector
Click HERE for the goodies to install a single N54 Fuel Injector
Reply
Aug 12, 2014 | 02:28 PM
The N54 straight-six engine has earned several awards for engineering excellence; partly through novel turbocharging and advanced variable valve timing, but crucially, through second-generation piezo direct-injection.
ECS supplies a range of genuine BMW and aftermarket fuel injection components to help keep your E9x 335i/is making full power.
Genuine OEM Injector Replacement Kits restore your engine's brilliance by taking care of the entire system in one servicing; Fuel Injection Harnesses, Fuel Filter/Pressure Regulator Repair Kits, and Injector Repair Kits are also available.
Click HERE for your E9X 335i N54 Fuel Injection Components
Reply
Oct 3, 2014 | 10:48 AM
Includes 6 injectors, seals, and decoupling rings
High pressure fuel injector supplies fuel from the rail to the cylinder
Click HERE for your N54 Fuel Injectors Installation Full Set Kit
Everything you need to install new fuel injectors
Fuel Injector Installation Single Kit
Everything you need to install a new fuel injector
Reply
Oct 7, 2014 | 10:45 AM
Reply
Mar 23, 2015 | 11:09 AM
Click HERE for your E9X 335i/IS N54 Fuel Injection Service Kits
Reply
Jun 24, 2015 | 09:50 AM
Click HERE for your E9X 335i/Is/Xi N54 Fuel Injection Service Components
Reply
Subscribe
