PCM2 to retrofit
Old Mar 21, 2009 | 08:43 AM
cerquoni's Avatar
cerquoni is infamous around these parts
PCM2 to retrofit
HI all,
I'm thinking to retrofit my 2007 porsche boxster 987 with a PCM2 navigator module.
I've seen that this is quite possible, difficult is to find exactly the compatible module. (with, w/o bose, ampl issue, ecc). Now I've just the CDR24 without bose system.
Anyone of you did do that without problem?
Any suggest to find on line shop or dealer to buy the PCM2?
I've seen that here in USA is simplier to find porsche parts accessories, instead of Europe I mean..
Toni
Old Mar 21, 2009 | 08:44 PM
braddmlewis's Avatar
braddmlewis is infamous around these parts
I have Bose and i changed my CDR-24 for PCM2.1 with Nav - No issues. Suncoast got me the parts and i installed it and then had Porsche code the PWIS. Will run to 3K most likely if you want to do it.
Good luck!
Old Mar 22, 2009 | 04:46 AM
cerquoni's Avatar
It sound like PCM 2 it's not the correct hardware right?
and it's necessary the PCM2.1?
I thought that the PCM2 was easierto install (my car hasn't bose) because it hasn't separate DVD driver.
But I don't know if my ideas are right.
Sorry what is the PWIS? A code to unlock the system?
Old Mar 24, 2009 | 09:28 AM
Hi the PCM for a 987S is 2.1 There are 2 units - one for Bose Cars, one for Non-Bose.
PWIS is the system that Porsche use to programme our cars and you will need them to activate.
You also need to be careful to makesure if you are doing NAV and PCM that the versions of code on the PCM and NAV are compatible.
If you need more information PM me and i will answer anything else you need.
My advice - Contact Ric from Suncoast Porsche who helped me do my PCM, NAV, Sirius and Bluetooth install..
Old Mar 24, 2009 | 09:59 AM
cerquoni's Avatar
Thank you for helping me..
I contacted suncoast many days ago for aPCM2.1 quote but i didn't receive any contact yet.
Have you Ric's mail?
I can contact him directly
Regards
Toni
Old Mar 24, 2009 | 10:24 AM
Old Mar 31, 2009 | 11:06 AM
cerquoni's Avatar
I found a low price PCM 2.1, part# 997.642.143.10 that is for a bose system (the same for no bose is the part# 997.642.141.10 ).
Someone says that is possible to use that part also in a no-bose system, just to re-coding the PCM using PWIS,
Is it really true?
Do you have experience regarding this issue?
Old Mar 31, 2009 | 03:01 PM
I almost 100% certain that you CANNOT use a bose PCM in a non-bose Car. It cannot be coded to work but you can change a non-bose PCM to work in a Bose Car.
Old Mar 31, 2009 | 03:04 PM
You may also wish to read this thread that is informative
Best of Luck !
http://www.planetporsche.net/cayman-...il-prices.html
Old Mar 31, 2009 | 03:22 PM
cerquoni's Avatar
I just red that.
But I red aldo this thread:
http://www.planetporsche.net/cayman-...-decision.html
suneet says:
"there were actually 2 PCM2.1B revision units for the Boxster (B-units play mp3's) that didn't have amplifiers built in...
997.642.143.03 and 997.642.143.02 are the two"
The 997.642.143.10 could have the ampli inside?
Old Apr 1, 2009 | 06:48 AM
cerquoni's Avatar
Finally I found exactly the parts I need:
PCM 2.1: part# 997 642 141 10
Navigation drive: part# 997 642 157 01
There are no items on ebay right now but if
anyone has that used part to sell, please Pm me
Old Apr 2, 2009 | 12:25 PM
You will also need some other components such as antenna and mounts and fittings..
Good luck - I am VERY happy i did my PCM/NAV install.
Old Apr 15, 2010 | 04:10 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
I have all the parts for sale if you guys are still looking for this.
Here is the link:
https://www.6speedonline.com/forums/...using-etc.html
Studio RSR
Nissan GTR Vendor Classifieds
Jan 29, 2016 01:24 PM
Studio RSR
Nissan GTR
Jan 29, 2016 01:21 PM
Studio RSR
Other Japanese Supercars
Nov 10, 2015 07:45 PM
Studio RSR
Lexus Vendor Classifieds
Nov 10, 2015 07:36 PM
