New 325mm Big Brake Kit!
SubscribeHey guys,
We just started carrying a new big brake kit for '99-'08 996/997 C2/C4 (Non-TT, Non-S), and all 986/987 models!
"Upgrades the stock 305 mm brakes to 325 mm, and increases the brake pad surface area. This kit offers a substantial increase in braking power, with a factory look. This kit uses factory calipers, rotors, and brake pads. It also comes with a CNC machined rotor hat to fit your car, as well as Stainless Steel Brake Lines and Pentosin Racing Brake Fluid. This is a direct fit, comes with your choice of Red or Black calipers."
http://e-partssales.com/Merchant2/me...tegory_Code=WS
They're not the same stock brake pads that are on your car. They are the bigger rotors and pads from the 993 Turbo.
Quote:
Ah o.k. that makes sense. I got a little confused when you mentioned 'factory ....pads.' I assumed the same as what's on stock Boxsters now from the factory.Originally Posted by SuncoastSteve
Whats the width of the rotors? None of the stock 986 or 996 or 987 or 997 brakes (non-TT or S) are 305mm. They are 318mm except for base Boxsters. 325mm doesnt seem like much unless they are wider. What is the weight of the rotors with the aluminum hats? The hats are not factory, right?
Do you offer any larger rotors and caliper kit? 14 or 15 inch rotors? Don't see the point of upgrading only 20mm larger rotors...
