987 Fuse Map?
Old Jun 9, 2008 | 02:02 PM
Mikli's Avatar
Mikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to behold
987 Fuse Map?
Can anyone scan a 2008 Boxster S fuse map for me? I lost mine.
I was adding air to my tires this morning with a 12v plug air pump (with the engine off). I had about 15 seconds worth of power than gone!! No power from both of mine 12V plugs (footwell and center)??? So I want to check my fuses...
Old Jun 10, 2008 | 05:44 AM
nick_usa's Avatar
nick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud ofnick_usa has much to be proud of
Try this link, the fuse assignments should be the same:
http://www.caymanclub.net/downloads.php?do=file&id=165
BTW the fuse you are looking for is Row A fuse 10 (15 Amp)
adnanm3
Oct 25, 2016 08:38 AM
White991TT
Mar 8, 2016 06:01 AM
