Tire pressure / nitrogen ?
Old Oct 9, 2008 | 09:13 AM
lucky_topher's Avatar
lucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant futurelucky_topher has a brilliant future
I have michelin pilot sports on my 986... they say 51psi max... when i got the car from the dealer there was a sticker saying my tires had been filled with nitrogen.... now i'm wondering would this affect how a tire gauge reads it? They're showing about 35psi now which seems very low... is that normal for a nitrogen fill? can i go ahead and just add regular air to them to the desired psi?
Old Oct 9, 2008 | 11:07 AM
Jorgeassoc's Avatar
Jorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant future
Anytime i have ever filled my tires with N, i never mix with with anything else.
I think its best that you call your dealer and ask them yourself. best of luck
Old Oct 9, 2008 | 01:56 PM
ofishbein's Avatar
ofishbein is infamous around these parts
Max pressure is not the same as recommended. You should probably be at about 29/36 front/rear.
Old Oct 9, 2008 | 02:24 PM
Mikli's Avatar
Mikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to beholdMikli is a splendid one to behold
Don't just add regular air if you had a choice. 29/36 is cold PSI for 18" tire set up.
Old Oct 10, 2008 | 09:32 AM
Kirk's Avatar
Kirk is infamous around these partsKirk is infamous around these parts
The max pressure on the side of the tire is not the recommended pressure from Porsche. Your owner's manual will have the recommended pressures. I personally run 32 front/34 rear. I think recommended front is 29.
Pressure is pressure, it will read the same on your gauge with nitrogen or air.
If you plan on continuing to only use nitrogen and have someplace where you can do this, then only use nitrogen. If you don't care, then fill it with air. It won't hurt to mix them as air is mostly nitrogen anyway.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
