Oil Change & Headlights
Old Sep 10, 2003 | 01:08 PM
99boxter's Avatar
99boxter is infamous around these parts
Question Oil Change & Headlights
how can I change my own oil? any specific way to do it or just like a regular car. In my 99 boxter, i still have yellow lights...i want to change them to superwhite? how and which ones should i put in?
I heard piaa is good. Help please!!!!!!!
Old Sep 11, 2003 | 09:25 PM
Tool Pants's Avatar
Tool Pants is infamous around these parts
Just like any other car, except there is a plastic cannister for the filter.
Remove the cannister, relpace the filter element, and O-ring on the cannister. With a 10 quart drain pan under the car.
Remove the drain plug and let oil drain. Replace plug with new crush ring.
Fill with oil. Jeff
Old Sep 14, 2003 | 03:43 PM
bobc4s's Avatar
bobc4s is infamous around these parts
Beware
Be careful most after market bright lights produce too much heat . The light housings on your car are plastic and most of the after market lights will melt the plastic housing.
Old Sep 15, 2003 | 12:21 PM
Parker's Avatar
Parker is infamous around these parts
I read similar about any aftermkt bulb over 55w. There are other xenon-emulating bulbs that are 55w which you can find all over eBay.
Old May 3, 2008 | 05:56 PM
ramone's Avatar
ramone is infamous around these parts
“Seal Grey Matte”
Manual Car (Stock) ..............Manual Car (after Tune)
416 hp ...............................599.08 hp
19.7 % of loss .....................19.7 % of loss
334 hp to the wheels ............481 hp to the wheels
44 % increase in power Crank
44% increase in power at the wheels
“Ramone”
Automatic Car (Exhaust) ........Automatic Car (Exhaust + Tune)
454 hp crank ........................600 hp crank
30% of loss ..........................30% of loss
318 hp to the wheels .............420 hp to the wheels
32.1 % increase in power Crank
32.1 % increase in power to the wheels
“Deandob”
Automatic Car (stock) .............Automatic Car (Exhaust + Tune)
416 hp crank .........................600 hp crank
30 % of loss ..........................30% of loss
291 hp to the wheels ..............420 hp to the wheels
44% increase in power Crank
44% increase in power to the wheels
Old May 3, 2008 | 06:21 PM
valter's Avatar
valter is infamous around these parts
Excellent post, Jeff!
These 2 tq.specs were also helpful for me:
Drain plug: 37 ft-lbs
Filter housing:
18 ft-lb
not to hijack this thread, but where can I get a quality filter wrench? I broke the crappy Advanced Auto one last time trying to undo housing even with PB Blaster
Old May 3, 2008 | 06:56 PM
blinkwatt's Avatar
blinkwatt is infamous around these parts
Pep Boys has an oil filter wrench that works perfectly.
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
