987 stock exhaust sound modification.
Old May 4, 2009 | 08:56 AM
porsched4ed's Avatar
porsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud ofporsched4ed has much to be proud of
difficulty rating 1 to 10: 1.5
tools needed:
-13mm deep socket
-ratcheting wrench
for elimination of drone optional:
-air cut off wheel (recommended)
-dremel
Not sure if this mod has any performance gains but it sure does sound and feel like it. I was just curious after realizing TechART had a "sound box" muffler tip add-on for the stock exhaust system. They said it made the car sound more aggressive but were not sure about performance gains. Here is what I did:
No need to jack up the car just get your 13mm deep socket and wrench. See the cross over pipe over the tip.
Loosen the two 13mm bolts.
Once loose the sleeve can very easily slide over, slide it over now.
You can see there is only a slight gap between the pipes.
wpmjr cut the end of the pipe and it helped reduce drone. Here is an example of what he did. The red line shows where to cut.
It seems that there are slight differences in each exhaust or how they are fit because mine had a larger gap already. Another good idea would be to cut a triangle or U out so you can use the sleeve to adjust the sound by sliding it back and forth. Thats what I did here:
You can see now it can control the sound better, it also eliminates drone.
Now tighten both bolts again, so they wont rattle or fall off. The sound is alot louder and deeper. It only takes 5min. These video clips kinda suck but its better than nothing.
Click below for stock video clip:
stock video by audis4ed - Photobucket
Click below for modified stock video clip:
modified stock exhaust video by audis4ed - Photobucket
I drove and checked it out on the ButtDyno and it certainly felt like it had more kick, probably not though. The sound is great too. Pretty cool and cheap mod if you wanna see how your car might sound with an aftermarket exhaust.
Old May 6, 2009 | 10:14 AM
bfischer's Avatar
bfischer is infamous around these parts
Interesting... so does exhaust escape now? Wouldn't it heat up that area?
Old May 6, 2009 | 03:21 PM
I drove it around like that for a while, didnt have any issues.
Old May 20, 2009 | 09:11 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Question
so you put a hole in your exhaust?
Mini George
Jul 29, 2019 12:20 PM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
Vrseis
Aug 20, 2015 07:41 AM
