Rear Stress Bar
Old Sep 4, 2009 | 09:49 AM
Johnny Danger's Avatar
Awaiting Email Confirmation
Johnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to beholdJohnny Danger is a splendid one to behold
Rear Stress Bar
Does anyone have any experience with using a lower rear stress bar ? Essentially, this item bolts to the rear sub-chassis just behind the triangular stress plate. This product is designed to keep the rear camber in place and "tighten" things up a little bit better. I know that Mantis Racing makes a popular one.
Old Sep 4, 2009 | 10:02 AM
EJ_2001_986_S's Avatar
EJ_2001_986_S is infamous around these parts
A number of people over at PPBB have put them on and IIRC the overall response is that it appears to work as advertised, no hard numbers to back it up though. There's 3 or 4 vendors of them, Mantis, Pedro, I think Schnell, they should be easy to shop around for.
Old Sep 4, 2009 | 12:43 PM
Cajundaddy's Avatar
Cajundaddy is infamous around these parts
Yep. Got one... I like. I do notice more precision from the rear of the car at traction limits. Useful for track or AX where you spend a lot of time at the ragged edge. Not much benefit for a street car.
Old Sep 28, 2010 | 01:17 AM
chaud's Avatar
chaud is infamous around these parts
Originally Posted by Little Gator
Does anyone have a recommendation for how to press out the 2 studs so I can install a stress bar? I tried to first let some penetrating oil work its' way into the hole and then tried to tap them out with a soft mallet. But neither would move. I am concerned that if I get more aggressive with a big hammer, that I could crack the aluminum sub-frame the studs are pressed into because it is less then 1/2 inch thick. Using a jack on it only managed to lift the car up, and the stud didn't budge.
If I remember correctly, I had a bit of time getting them out at first since I was holding back. A good solid whack dead on should get it right out.
(Try to loosen the nuts slightly first, then give it a good solid whack so that it moves... then remove the nut, and remove the stud/bolt out upwards from the top)
Old Sep 28, 2010 | 01:20 AM
chaud's Avatar
JD, I've got a solid bar, and it does tighten the rear up, and worked as advertised, so to speak. I definitely noticed a positive handling change with the addition of the bar. In my opinion, it is well worth it for a relatively inexpensive mod.
Old Oct 14, 2010 | 07:07 AM
harryrcb's Avatar
harryrcb is infamous around these parts
Got One, works great, makes a lot of sense to have one, don't know why Porsche didn't put it there in the first place.
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
GTstreet996
10
Sep 26, 2015 01:03 PM
The Oss
Aug 24, 2015 08:19 PM
