Replacement strut/shocks
Old Dec 13, 2009 | 04:02 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Where's the best place to purchase replacement front strut/shocks for and 01 S?
My front right strut is blown(leaking) and steering vibrates randomly at higher speeds. I'm looking to replace both front ones only. Not looking for an upgrade as its my daily beater. Bilstein has a HD and a sport version. Any difference?
Thanks.
Old Dec 13, 2009 | 11:52 PM
Cayman Cab S's Avatar
Cayman Cab S is infamous around these parts
I've got the Bilstein HD's on my 05 Boxster S, 19" wheels, standard non PASM. I think the Sports are a little stiffer. HD's are fine for me, less body roll, less brake dive, more responsive steering, less scraping on driveways and speed bumps. More jiggly on rough pavement.
Old Dec 14, 2009 | 11:25 AM
geetee's Avatar
So the Sports are more stiff than the HD's? I was thinking it was the other way around.
I'm still debating whether to go the ROW suspension for 1100+ labor for all 4 corners and F+R sway bars or just the front 2 shocks for 450+labor.
BTW 75k miles with original suspension
Old Dec 14, 2009 | 02:38 PM
I'd replace all 4 shocks, if you are at 75K miles. About $1100 including labor for my car. Sports are a little stiffer, which I did not want, having 19" wheels, non PASM.
Old Dec 14, 2009 | 05:35 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
It really depends on what you intend to do with the car after you put the new parts on. If you plan to race it, you may want to consider a coilover setup for adjustability/tunability. If you plan to do DEs a few times a year, for less money than the coilovers, and achieve similar results (firmer ride, better handling, don't mind jarring ride on rough roads - you can go with a set of aftermarket springs & shocks (as others are suggesting). By the way, stiffer ride will eventually lead to more squeek and creaks inside your car, and you can't fix squeeks. Finally, if you liked the factory ride you had before, you can save money with a set of OE shocks and springs, and be quite happy. I know someone who couldn't be happier after he replaced the his worn out suspension with new factory setup. It's all about trade-offs.
Old Dec 14, 2009 | 06:42 PM
geetee's Avatar
The Boxster is used as a daily beater in rain/snow. I don't want to put much money into it as its driven 20k+miles a year.(Weekend or good weather is reserved for the C2). The factory suspension is fine but I'm not sure what suspension option it came with. I want to keep the springs but can't decide on the HD or sport Bilsteins.
Old Dec 14, 2009 | 08:08 PM
HD with OE springs will do just fine. If the springs have 75k miles... and you are paying for labor, you may consider changing the springs as well.
Jun 10, 2017 07:45 PM
henryr
Sep 24, 2015 08:22 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 24, 2015 09:29 AM
Jeff1smith
Aug 19, 2015 09:41 PM
