program garage door
Old Apr 17, 2010 | 05:13 PM
CaymenSKid's Avatar
CaymenSKid is infamous around these parts
program garage door
Does anyone know how to program the homelink garage door opener in a 06 cayman?
Old Apr 17, 2010 | 06:16 PM
extanker's Avatar
extanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond repute
for an 09 you push the learn button on the garage door opener then go to your car and keep hitting the switch until the door closes
Old Apr 18, 2010 | 02:21 PM
Risky_Business's Avatar
Risky_Business is infamous around these parts
Iirc....
Page #106-#107 of the manual.
1, 2, 3
- Programmable buttons
A
- Light-emitting diode for status identification
HomeLink
The programmable HomeLink replaces up to three
original hand-held transmitters used to operate
various devices (e.g. garage door, gate to the
property, alarm system).
You can program buttons
1 to 3 with a frequency
of an original handheld transmitter.
Risk of accident when using the HomeLink if
persons, animals or objects are within the
range of movement of the equipment that is
being operated.
f
When using the HomeLink, ensure that no
being operated.
f
Observe the safety notes for the original
hand-held transmitter.
Preconditions for operating and
programming the HomeLink:
– Ignition is switched on.
– Daytime driving lights/fog lights are switched
off.
To operate the respective device:
f
Press the appropriate button (1, 2 or 3).
A lights up during signal
Note on operation
f
Always use the HomeLink opener in the
direction of travel.
Otherwise, range restrictions cannot be ruled
out.
f
Before selling the vehicle, delete the
programmed signals of the HomeLink.
f
Please read the instructions for the original
hand-held transmitter to find out whether the
original transmitter is equipped with fixed or
changeable code.
f
Always fit new batteries in your hand-held transmitter
before programming the transmitter.
Allocating signals to the buttons
f
Please follow the operating instructions for the
original hand-held transmitter.
Prior to programming the HomeLink for the
first time
The following process deletes the standard codes
set at the factory. Do not repeat the process if you
program further buttons.
f
Keep the two outer buttons 1 and 3
depressed for approx. 20 seconds until lightemitting
diode
A begins to flash quickly.
All programmed signals of buttons
1 to 3 are
deleted.
Programming HomeLink with fixed code
1. Press and hold the desired button until the
light-emitting diode begins to flash slowly.
You then have approx. 5 minutes to perform
steps 2 and 3.
2. Hold the original hand-held transmitter approx.
0 to 12 in. (0 to 30 cm) in front of the marked
position (figure) on the vehicle.
3. Press the transmit button on the original handheld
transmitter until the daytime driving lights
flash three times (up to approx. 45 seconds).
4. Repeat steps 1 to 3 to allocate other buttons.
Programming HomeLink with changeable
code hand-held transmitters
steps 2 and 3.
4. To synchronize the system:
Press the programming button on the receiver
for the garage door actuator.
Afterwards, you usually have approx.
30 seconds to initiate step 5.
5. Press the allocated HomeLink button twice.
(With some devices, the button to be allocated
must be pressed a third time in order to
complete the setting process.)
6. Repeat the programming steps to allocate
other buttons.
Note
Several attempts with different distances between
the vehicle and the original hand-held transmitter
might be necessary.
The daytime driving lights will flash once the 5
minutes have been exceeded. Programming must
be repeated from the beginning.
f
Please consult your authorized Porsche dealer
if you have not been able to successfully
allocate signals for the garage door opener to
the buttons even though you have carefully
followed the instructions in this chapter and
the operating instructions for the original handheld
transmitter.
Deleting programmed signals of the
HomeLink
(e.g., when selling the vehicle)
1 and 3 depressed
for approx. 20 seconds until light-emitting diode
A
1 to 3 are deleted.
- RB.
NC 996TT
Mar 23, 2023 06:19 AM
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
GSP
Sep 9, 2015 05:31 AM
sparks
Sep 8, 2015 03:03 PM
