Boxster Wide-Track Suspension & Big Brakes Swap Help!
Old Aug 18, 2010 | 10:12 AM
alipendier's Avatar
alipendier is infamous around these parts
Cool Boxster with Cayenne Suspension & Big Brakes Upgrade Swap Help!
Working on my 99 Boxster and I would like to know any available upgrade swaps for suspensions and big brakes. Can the Cayenne brakes/ suspension parts work?
Any suggestions? Thanks
Old Aug 31, 2010 | 10:15 PM
budmanv24's Avatar
budmanv24 is infamous around these partsbudmanv24 is infamous around these parts
Boxster s/996 brakes are a relatively easy swap. I've seen kits for 996's to bolt up Cayenne calipers, so i couldn't see why you couldn't do it on a 986. You might have to swap the master cylinder. And sometimes you can run into compatability issues with the dme and abs when swapping calipers. So be careful when going radical. Also, adding cayenne calipers not only requires much bigger wheels, but also adds a lot of unsprung weight.
Old Sep 5, 2010 | 03:08 PM
alipendier's Avatar
Cool Thanks for the replies!
I am already going to increase the wheels to 20", do you have any links to the kits for the 996 using Cayenne calipers? Thanks
Old Sep 9, 2010 | 08:33 PM
og risker's Avatar
og risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud of
Originally Posted by Josh@TPCRACING
alipendier,
There are a lot of options when it comes to suspension/brakes upgrades for your 986. What are your intended uses for the car?
We have a number of different suspension options designed for everything from simple street driving, to full professional race setups.
When it comes to the brakes, we have many different option from simple brake pad upgrades, to full brakes swap, to help you get the car hauled to a stop! You should not be using any Cayenne components on your 986. These are SUV components designed only for usage on an SUV. They were not designed for a sportscar that could see extended periods of hard usage at high temps, like out on a track.
It takes a very high level of expertise to get these cars PROPERLY sorted out. At TPC Racing, we have a long history of PRO RACING, and can help you find the setup that is most appropriate for you!
Please, give us a call, or drop me an email and we'll design a package just for you!
Josh B
TPC Racing
410-799-RACE(7223)
jbers@tpcracing.com
Dude, The Pro's @ TPC just said not a good idea to use Cayenne brakes. Listen to Josh...
Old Sep 9, 2010 | 09:13 PM
budmanv24's Avatar
And why would sextuple piston Brembos not be an ok idea? I agree that Cayenne suspension isnt gonna work on a Box, but whats wrong with big ole brembo brakes? I take it if he's runnin twenties that he's going more for looks than winning races and isnt worrying about unsprung weight or brake bias. The PCCB brakes are 6 pot brembos.
Old Sep 10, 2010 | 07:48 AM
alipendier's Avatar
Cool Thanks for replies!
I am aware of SUV calipers and brakes being used on regular cars like the Chevy S10 being swapped into the Pontiac Fiero, and my understanding is that the Cayenne just has better Brembo brakes thats all, I am consideing the pros for suspension but I am sure that there are ways to upgrade the brakes by doing swaps.
What are the swaps needed for a complete brakes upgrade? so far I know the:
- calipers
- rotors
- pads
- Maybe master cylinder
- and stainless steele lines
Old Sep 10, 2010 | 07:55 AM
steve0827's Avatar
From: Waltham, MA/Southport,CT/Vero Beach, FL/Grosse Pointe, MI
steve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to all
Like stated before, I personally believe you should just get a big brake kit from Brembo. It probably will be more expensive, but big brake kits are pretty darn good.
Old Sep 10, 2010 | 08:48 AM
budmanv24's Avatar
You're gonna have to find someone that makes adapter brackets to mount the calipers. They're not gonna be a direct bolt on. I would advise upgrading the rear brakes too, otherwise you'll be doin stoppies (aka front bumper will be hitting the street and your back wheels will come off the ground). If you can't find any off the shelf adapters I can design some for you.
Old Sep 11, 2010 | 09:32 PM
lobo1186's Avatar
lobo1186 is infamous around these partslobo1186 is infamous around these partslobo1186 is infamous around these parts
- calipers
- rotors
- pads
chevy s10 brakes into a fiero is hardly comparable to cayenne brakes into a boxster. for starters the s10 is basically a car in the first place and are crappy chevy brakes to begin with.
anywho. if you want just big brakes for looks your best bet is rear S calipers from maybe a 911 and brembos up front. if not maybe the six pots. do you have cayenne calipers sitting around or something? is that why you are set on using them? if not its probably a waste of time and looks.
Old Sep 14, 2010 | 07:11 PM
alipendier's Avatar
Cool
I am mainly trying to get the 14" rotors upgrade since I am upgrading HP and I would be using 20" rims
Old Sep 14, 2010 | 08:24 PM
budmanv24's Avatar
What power upgrades, 3.4? Do 20's fit? That might be pushinit, 19's might fit better, plus the calipers and rotors will fill them out better. And if u find a way to mount cayenne calipers there's someone over on rennlist (no relation) trying to unload a set. 996/boxster s brakes would be a much easier upgrade but wouldn't look near as cool.
Old Sep 17, 2010 | 10:31 PM
alipendier's Avatar
Cool
Thanks for the info! I didnt see the calipers on rennlist, do you have the link? Thanks
Old Sep 18, 2010 | 01:32 AM
racin's Avatar
racin is infamous around these parts
after all the hastle and time trying to put on cayenne calipers and find a rotor that will fit you lug pattern and has proper offset youd probably have spent more money than if you bought a brembo big brake kit. its tried and tested and will bolt on in a few hours, youll be much happier than spending weeks with your car on blocks trying to cluster something together. and 20's.... porsche engineers spent countles hours redisgning the suspension of the 987 models to make just 19's work properly. you will not be happy with the ride and the performance. it may look good to some people but that is all they are good for.
Old Sep 18, 2010 | 09:49 PM
alipendier's Avatar
Cool
Thanks for the info and I will do a search for the brembo package, but I have also been considering this set here if they are legit...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Sep 19, 2010 | 09:35 PM
budmanv24's Avatar
Have you heard of anyone else using that setup? Looks suspect. How available are replacement parts and are different pads available? And check your pms.
