widest tire for fronts
Old Feb 20, 2011 | 12:05 AM
dyc1077's Avatar
dyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud of
The tire shop put on the wrong size tire on my front wheels. They were supposed to put 235/35/19 but ended up putting on 255/35/19. Should I spend the effort and time to go back and have them put on the correct tires? Or will the car handle fine with these wider fronts? I am running 275/35/19 in the rear
David
Old Feb 20, 2011 | 08:16 AM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Depends on the wheel width and offset. 255 may work, but tires may rub wheel liner when you are at or near full lock. I wouldn't be surprised if that's the case with your setup. Someone I know went with wider tires (not sure the size) on a 986 and tires wore through the wheel liner and into the radiator hose which caused a pin hole leak.
If I were you, I would go back to the tire shop and get them to put the right ones in very soon - assuming you didn't tell them you want 255's in front. Most wheels sized/offset for 987's run 235 fronts and 265 rears, a smaller percent of us run 245 & 275's. Some time people don't pay attention and put the wrong thing on.
Old Feb 20, 2011 | 09:41 AM
jmc777's Avatar
jmc777 is infamous around these parts
If it were me I would expend the effort to get the correct tires.
Old Feb 20, 2011 | 11:47 PM
2slow2speed's Avatar
2slow2speed is a jewel in the rough2slow2speed is a jewel in the rough2slow2speed is a jewel in the rough2slow2speed is a jewel in the rough
IIRC, if the % difference between the front tire and the rear tire does not remain within a certain range then the ABS computer might get confused.
There is a thread over planet-9 that is discussing the issue right now:
http://www.planet-9.com/cayman-boxst...0-18-rear.html
BTW: Love the P43 HRE's, have a set of them in matte black sitting in the garage.
To the OP: Did you get some black center caps for the HRE wheels?
Old Feb 21, 2011 | 06:38 PM
dyc1077's Avatar
thanks for the info guys. I called and they are ordering the correct size to put on for me.
2slow2speed: i didnt get blackcenter caps. do you have some? any idea on costs?
Old Feb 21, 2011 | 11:26 PM
Sadly I am on the same boat as you, can't figure out why HRE doesn't provide a matching colored center cap . Best bet might be to try an aftermarket Porsche replica center cap in black. Been looking for one from some of the Porsche replica wheel vendors.
Enemy
Nov 10, 2015 08:01 AM
COBB Tuning
Nov 9, 2015 08:02 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
