Cayman S... Any tips?
Old Mar 21, 2012 | 08:55 AM
Ichiban's Avatar
Ichiban is infamous around these parts
Any known problems I should look out for when purchasing a Cayman S?
I'd probably end up with one having no warranty since I will be buying the car in the States and importing it into Canada.
Anything I should look out for or any known problems on the 06' models?
Thanks in advance!
Old Mar 21, 2012 | 12:01 PM
PNug's Avatar
PNug is infamous around these parts
Depends on how you want to use the car? As a street car you should not have any real issues. Once you start tracking the car, you need to look at oiling issues and steering pump over heating. The first is the bigger issue, the steering pump is not a big problem just need a cooler. Check out Planet-9's website and those topics.
They are great cars.
Old Apr 5, 2012 | 08:47 AM
Ichiban's Avatar
Probably street car for now...
I'm looking to do some HP upgrades first thing on my list.
Old Apr 5, 2012 | 03:21 PM
PNug's Avatar
joint Planet-9 website for the best info on the 987s
I'd add a windage tray and 996 swirl pots at the least before you start going crazy with HP upgrades. There are a few under $1k upgrades I'd consider the Carnewal exhaust exchange, desnork, underdrive pulley from BBI and then go to the intake and mapping.
Planet-9 has all info you'll need.
Enjoy!
Old Apr 5, 2012 | 03:42 PM
sharkster's Avatar
The power steering line/coupler failing/melting. That was my biggest pet peeve!
You can see my 06 here:
http://sharkwerks.com/porsche/987-ca...n-s-rs350.html
Old Apr 5, 2012 | 08:15 PM
Macster's Avatar
Thanks in advance!
The car is just a used car so a thorough used car checkout will go a long way to helping you spot a car you do not want to own.
Give the car a good longish test drive, 15 miles as a passenger and then 15 miles (the same route) as a driver.
You want to give the engine and the rest of the car plenty of time to manifest any problems and running the engine, driving the car, is the only real way.
After if you still like the car and believe you can swing a deal the seller and you can both live with have the car treated to a PPI and if it passes this buy and enjoy.
Sincerely,
Macster.
Old Apr 6, 2012 | 09:02 AM
extanker's Avatar
extanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond repute
Thanks in advance!
PM sent
ChuckD06S
Sep 28, 2015 06:23 PM
ModBargains
Sep 12, 2015 12:55 PM
brickdawg
Sep 11, 2015 09:08 PM
