Im not going to have engine problems right? 2011 spyder
Old Apr 3, 2012 | 02:59 PM
extanker's Avatar
extanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond repute
a car running "R" tires corners much faster ,oil will /can move away from the oil pump pick up in the sump/oil pan........the motor grenades
Old Apr 3, 2012 | 03:44 PM
PNug's Avatar
PNug is infamous around these parts
higher lateral G's for sustained long turns can cause problems for any car. So when you put R compound tires on, lower and tune the suspension bad things can happen if you don't address the issue. 1st Gen 987 have a little more of a problem than most and the rod bolts are a weak point on the 1st Gens. 2nd Gen 987 are a little better but I'd be cautious about the above mods on any car without taking measure to protect the flow of oil inside your engine.
Jul 29, 2019 11:13 AM
007AMV8
Oct 19, 2015 09:55 PM
MrNurse
Sep 10, 2015 09:44 AM
PelicanParts.com
Aug 25, 2015 03:35 PM
JMon
Aug 21, 2015 08:20 AM
