TT 500+ Cayman on the making
Old Oct 24, 2012 | 05:04 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
This is a car for life IMO you go this far and its like having another child . I cant wait to see the results !! and i hope you keep her forever as I would !!!
Old Nov 29, 2012 | 04:47 PM
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
any updates?
Old Dec 5, 2012 | 07:52 AM
Markvonreitzenst's Avatar
Markvonreitzenst is infamous around these parts
Sorry, not yet, the tuner, Proto-Tech is taking longer than expected, not happy about it but let’s wait on the outcome
Old Dec 27, 2012 | 05:49 AM
Velocitytrap's Avatar
Velocitytrap is infamous around these parts
Bump for an upate.
OP have you followed the IMA Motorsport build? Their kit was a twin turbo with variable vanes like your build. They seemed to have difficulty with building boost down low around 3000rpm or less. I'm not sure how much time they had with the car to tune though.
I can't remember the size of the engine that they were using but I would think the 2.7L would be harder to make more boost lower than the larger engine. They posted a dyno chart. I know that you are shooting for more whp and with a stout whole engine rebuild it will be easy to turn up the boost to attain the nubers that you want. How are these two turbo kits (IMA and yours) different? Have you considered a sequential Bi-turbo setup? I would think that this would be a nice track setup.
Old Dec 27, 2012 | 11:40 AM
Fluid987's Avatar
Op...if they need Some software to make this car run properly have them contact Scott over at Softronics .he is the master
Any updates?
Old Dec 28, 2012 | 11:04 AM
henryzm's Avatar
henryzm is infamous around these parts
Would it be possible to see the car at your facility?
Old Dec 29, 2012 | 12:39 PM
Sure, the car is at Prototech in FL, if you want to go see it, just let me know so i can advise Dave
Old Feb 14, 2013 | 12:23 PM
TAch Miami's Avatar
TAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond repute
How's the car doing?
Old Feb 14, 2013 | 01:55 PM
The car is still sitting at Prototech. There were some delays with theTurbos and finally they arrived yesterday. Spoke with David Hart yesterday andhe will start bolting in the turbos, since it was all set before since we hadMock Up turbos, so is a bolt on thing now. He said that he will start the carnext week and see how it all looks, he still needs to do tuning and check thatis all running properly. After that, we will need to break in the re enforcedengine before a final tune up and then take it to the Dyno.
It’s been a long ride, hope this car is running in 1 to 2 weeks, now allparts are in and ProtoTech just needs to work on final installation and tuning.
Once the car is running, I will continue with the post, I will post newpictures, car runs and Dyno test and results. Hoping the project ends up withcool results.
Cheers
Old Feb 18, 2013 | 01:59 AM
Sn1p3r's Avatar
Sn1p3r is infamous around these parts
The car might be yours but we are having sleepless nights thinking about it
Look forward to the update.
Cheers!
2lflat4
Nov 18, 2019 05:05 PM
awdbiturbo1
Feb 18, 2016 10:24 AM
Aug 20, 2015 12:17 PM
