987.2 tpc turbo kit - too lean ... any ideas?
Hi guys,
I am alex from germany. I posted the same thread over at P9, too.
I have a 987.2 Boxster S with the 3.4 DFI engine an dits modded by TPC
racing's low pressure turbo kit.
it runs fine and i can actually compete with R8's (the V8's of course only)
I have this problem though that the durametric logs show a much too lean
value I just logged lambda today and its freaking me out honestly.
I just emailed TPC:
hi mike,
when I went to my garage i did that throttle body thing
and brought it to 14V - all good
now - something that still gives me headache - even that the car runs better
now - it is still incredibly lean!
what do your DFI boxster or cayman S cars with the low pressure turbo kit
have in actual lambda value before cats?
mine is regularly above 1,0 - at times even up to 3,03!
check attached durametric log column F and G are lambda actual values
running too lean can easily bring your engine to blow
you know that more than i do
please have a look and let me know your feedback
thanks
alex
so the car is running better than before now - but its still incredibly lean.
can anybody else on this forum, like the recent cayman R build
duramtric log his lambda values - if all DFI cars are driving these
I foresee a dark future for our engine - a very recent dark one indeed
tpc's (mike's) response:
your using durametric you have no idea what those values are its unreliable
thanks - but how does this help exactly?
so I replied:
so what should i do then to get peace of mind on this too lean angst
that i have? who can log or better what system can log real a
head cat values for me correctly?
...so lets see
the guys on the german tuning forum
they drive driving porsche factory turbos modded up to 600-1000 hp
are telling me do NOT drive the car with this kind of lamda values
I have attached two durametric logs
I have to admit the support from tpc is at times very difficult
so you got to figure things out on your own i am afraid. What do you guys
say about the durametric's values reliability?
I understand all around the world it used even for ECU mappings - so that
would be strange if its values were not usable - would it not?
I really wish I could get a straight answer from TPC with their facts
it just is impossible...
what is normal according to their mapping?
what should I use to log?
porsche tester?
get a separate lambda tool
(what if the values remain the same more $$ down the drain)
what values should show in duramteric?
(thats why I asked for other DFI low pressure turbo kit cars here
like the cayman R who has the intercooler kit already installed)
thinking about this again.
it appears to be pure nonesense to me that the durametric values are wrong
i mean what does the durametric do other than reading out what the ECU
supplies in terms of data?
based on those lambda values the ECU is regulating the amount of fuel
that is injected. which is obviously too little
thanks for constructive participation
I just emailed TPC:
hi mike,
thanks
alex
so I replied:
...so lets see
porsche tester?
are the o2 sensors working and can you monitor them with a good scan tool ? does your CEL work and is it on ? i could not open your posted data file [my fault i,m not putor smart]did this problem just start or was it after some work?
Well, if the engine were really running lean I doubt it would be running as good as you report. A boosted engine running lean doesn't run lean for long before it lets you know it is too lean. Blobs of molten piston material generally leak from the exhaust tips.
Thus I question your diagnosis the engine's running lean. Which kind of agrees with what TPC says.
I'm unfamiliar with the Durametric system so I can't help you sort that out. I have used other OBD2 data readers/data loggers but my experience with them is of no help at this time.
Couple of things, some probably obvious.
You have to be sure all air the engine is getting is monitored air.
Check for intake air leaks. This includes a cracked/split oil filler tube and possibly a bad AOS.
Be sure the intake is getting fresh cool air. The turbo compressor heats it up enough as it is. If for some reason the stock air box or aftermarket air box is allowing hot engine compartment air to get into the engine this can upset the MAF.
Be sure the fuel system is in good working order. The DME assumes a pretty constant fuel pressure when it calculates how long to leave the injector on. The DME can only vary the amount of time the injector is open (well that and when to open the injector). If fuel pressure is low...The fuel pressure may not be consistent either. You have to consider an intermittent problem.
(But with no misfires I lean -- oh, no pun -- towards agreeing with what TPC strongly hinted at: The engine is not running lean. To put it another way: The problem is with your test tool, not the engine.)
Anyhow, moving on: Check for exhaust system leaks. This can upset the O2 sensor readings.
Be sure you have the right sensors. Some models -- I do not know if the engine/DME you have is one -- use narrow band sensors, others (996 Turbo for one) uses wide band sensors. I would think the DME would flip out if these were wrong but you never know. Also, who is to say that extremely lean lamba is not the DME flipping out?
Don't change anything or fix anything unless you are sure you have found a smoking gun. Even then be careful. There may be 2 problems, unless I like to add there are 3 or more problems or just one problem.
But before you delve too far into this I think you need to be really really sure of the engine's lean. It doesn't read like it is.
Sincerely,
Macster.
Sincerely,
Macster.
Hi,
thanks for the input
I should have mentioned that I did change
the Air/oil Separator as it was leakin goil
The fuel pump sitting in the gas tank
the DFI fuel pump (was changed by dealer last year as basically all early DFI models had a service call from porsche and theirs changed)
I checked all seals on the engine
I made sure there are no leaks in neither air intake system
nor exhaust
before the turbo mod my car would have black residue on the exhaust tips
(like all DFI engines do) - that is just not the case, either ever since the mod (that I have been driving for almost 5thousand KM)
i am afraid adding new sensors - will bring the same results - and eventually what the DME reads is the basis for its fuel supply regulating - is it not?
I thought of trying to replace the injectors to the ones from the 997.2 turbo (the part number at porsche is another - if they are bigger/deliver more fuel - I have no idea - but again if the DME/ECU is just not giving more fuel from its mapping then changing injectors may be a lost cause, too)
How about chances its the actual mapping? I mean softronic does ALL its work ONLY with durametric logs - isn't that right?
nor exhaust
here is a log from before changing the AOS and fuel pump n the gas tank
back in July.
at this time the airbox may have had a slight leak btw - possibly this was the
reason for the extreme ho tair intake temperature (column N)- but it
was really tiny
column G shows correction up to 30% - that seems enormous too
if it had to regulate/correct the fuel trim up ton one third!
what strikes me is column M - that has a max value of 120 Bar
afaik 120 bar is the stock max setting - now from the logic
if an engine gets more air through a turbo system but the fuel pressure
remains at its max similar to the stock setup = too little fuel delivery
does this make sense?
I will log those again to see if this changed
back in July.
was really tiny
Hi,
nor exhaust
nor exhaust
Absence any signs of a badly running engine, check engine light, the exhaust tips could be covered with pink polka dots for all that's worth.
I can't help but ask what is it your are seeking to fix?
If you suspect the engine is not being fueled properly you need hard proof of this. Just thrashing about acting upon what the exhaust tips look like or don't look like is not going to make things any better (they may be ok) and could make things much worse.
I am not familiar with the TPC system but if it requires higher flow injectors I think this would be clearly stated in the installation instructions.
My WAG is it doesn't. The DME has considerable adjustment to add more fuel when more air is brought into the engine courtesy of the super charger.
Now the DME might reach its enriching limits and turn on the CEL and log error codes to this effect.
A remap of the DME could raise set the adaptation points higher to avoid triggering the CEL. Does TPC suggest a remap?
If there are no O2 sensor related error codes I'd leave sensors alone, provided you are sure they are the right ones for the car, are installed in the right locations. (Some sensors can't be swapped from the #1 to the #2 position because they are quite different sensors even if they mechanically fit in the threaded hole).
O2 sensors are critical to proper engine fueling and just as importantly to the the converters health and proper operation and the DME checks them 6 ways to Sunday every time you start the engine and run the engine for any length of time. If there was any problem with the sensors, either because they were bad, or were not up to the task, I think you'd have a CEL and error codes pointing to the sensors.
Not sure about your question about the actual mapping and Durametric logs. But if you are implying that because of what you see using Durametric that the mapping may be wrong somehow, that could be -- given the limitations of my knowledge about the TPC and any remapping and how Softronic works, etc.
Sincerely,
Macster.
back in July.
was really tiny
back in July.
was really tiny
I'm not sure about a DFI engine but I am operating on the assumption is is the same as non-DFI engines. Fuel pressure at the injector is while high (quite a bit higher than non-DFI engines) the pressure from idle to max rpm is the same. If I'm wrong then what comes after is wrong too.
Fueling is based on a regulated supply of fuel supplied at a consistent pressure.
To avoid extra complexity the DME is built with the assumption operates on the assumption, calculates fueling fuel requirements and satisfies those based on a constant fuel pressure.
The DME supplies more fuel to the engine by extending the time the fuel injector is open.
There can be problems. First the fuel system must be in tip top shape. If for any reason the fuel pressure is not within spec or if under extremely high loads the fuel system simply can't deliver sufficient fuel, well, these are problems.
Generally aftermarket engine add ons rely upon the considerable margin in this case the stock fuel system has and it has considerable margin, provided it is working right 100% of the time.
Under lighter loads the fuel system can keep up, but if for instance the fuel pump can't keep up at high fuel demands the DME will at some point flag a problem when it reaches the limit of how long it can keep the injectors on.
AFAIK there has been nothing flagged. I still haven't seen any posts from you reporting a CEL and error codes that clearly point to a problem.
Now on a related note the fuel injectors need to be in tip top shape too. They are on more and as such they run hotter. If one or more are weak the higher cycle times can send marginal injectors over the edge. Injectors that may have been quite capable of supplying a stock engine with fuel for years and years with nary a problem.
Another area of possible issues. Air mass used to be measured by a mass air flow sensor (hot film). At some point -- I do not know when -- Porsche switched to using an air pressure (barometric) pressure sensor in the intake. Somehow this sensor's output with some other data at the DME can be used to determine air mass and thus how much fuel to add to produce the proper fueling.
Now obviously a supercharger changes the pressure in the intake system. The sensor -- if this is used in your car's engine -- could be confused by the big increase in pressure (and intake air temperature). Or it could be confused by the pulsing or non-laminar flow over/past/through the pressure sensor. Even if there is a MAF this can also be affected by these things.
However, TPC should have this covered, even if covertly by describing the proper installation steps. The result is that if the system is installed correctly proper operation is ensured, no abnormal air flow occurs that can upset the measurement of the mass of air the engine is ingesting.
In short, if the install is not right the system will not run right, the engine will not fuel right, and various sensor and derived readings will be wrong, worse that wrong, all over the map and having you chasing your tail following one phantom problem after another when all along it is a simple installation problem (well, relatively simple problem) that is the root cause of the behavior.
Sincerely,
Macster.
Here is lambda1 logged
appears not too lean - but I will have someone
with experience give me a feedback and I will re-confirm those
values with the porsche tester tomorrow
here is another concern
http://www.youtube.com/watch?v=cSJWU...3&feature=plcp
are those 6MT vs 6MT?
or PDK vs PDK?
at least same type vs same type?
because in all reality my car would NEVER EVER beat a GTS modded 987
here is a fact - my 100-200 km/h time is a flat 11sec
sometimes a tiny bit lower - and my car is a PDK!
to compare - a friend in germany has a gen1 car with a 911
3.6 engine conversion that delivers at 355 crank hp
he is driving an 11.7 (2 shifts 2-3 and 3-4)
so again people - i do NOT intend to bash TPC or anything
but I want people to know the TRUTH about the REALITY of the mod
they intend to do - and we, the customers, the people,
should put our results together to create a reliable feedback
on what those cars and mods really deliver
:thanks: for sharing your durametric and/or 100-200 runs with another
I would also ask TPC - since troubleshooting over the net is difficult,
why would you not try to create data that is of helo, as a benchmark
why would TPC not have duramteric logs
only
b1 actual and nominal lambda before cats and rpm
only
b2 actual and nominal lambda before cats and rpm
only
fuel delivery relevant values and rpm
only
mass air flow, load and rpm
see what i mean - it would take them a 3 hour of work to create those logs and then if a customer has a problem - tell him to compare his log runs with theirs - right now anything i sent them if looked at, at all - would never get a straight answer or solution - that if you got mike on the phone - it a little like
Never Get A Straight Answer and I thought Nasa was hiding the exisitence of aliens from us
anyhow I hope we as users - can help each other with creating logs and
benchmark data - or if all may have the same "problem" as I am facing
one thing is a fact THIS: http://www.youtube.com/watch?v=cSJWU...3&feature=plcp
is NOT my car's reality, and I checked and replaced so many things
and I do NOT have any fault codes either
thanks everyone
or PDK vs PDK?
only
only
only
only
thanks everyone
at idle ,closed loop you should see the o2 sensors mil volt around .450 varying, the more active they are [over 450 under 450 the better]. a data line called o2 cross counts will tell you their health,again the more the counts the better. o2 mil voltage below a certain number will pop a cel as will voltage over. unless you have the sensors tuned out. at WOT on the road you should see .800/.900,s mil voltage
sorry extanker - what exactly are you referring to?
what health do you mean? pls clrify and I will look for o2 something in durametric
if the sensors are tuned out its part of the ECU programming from TPC
k went to porsche today and logged with piwis
lambda ahead of cat looks fine at full load and top rpm around 0.79
and when you go off the gas it always goes around 1.0
so basically this looks ok
what the porsche technician spottet though was the values AFTER cat
he said those were moving quite a lot - and they should be rather
constant values
based on that the porsche technician said he would check the kats
possibly they may be stuck.
I emailed TPC:
so what is the course of action now mike?
should I take them out and empty them for a test?
would this interfere with the ECU programming?
or should I get other possibly sport cats?
if so which ones would you give an ok for?
please advise - thank you
so lets see...
constant values
I emailed TPC:
so lets see...
Mark @ AIM Performance
119
Jul 28, 2021 08:07 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
