Cayman Won't Start: Clutch needs to be depressed
Old May 17, 2013 | 06:02 PM
ttam110's Avatar
ttam110 is infamous around these parts
I have a 2007 porsche cayman that purchased six months ago as a flood car. I bought it as a DIY project. In order to get it up and running, I changed the fused box, relay box, all the computers on board (ECU, Driver assistant module, module inside the trunk, module inside the glovebox, and much more).
Now my problem is that the car does not start. I turn the key, but get the message that the “clutch needs to be depressed.” Obviously I try doing that, but it still gives me that message I checked the two limit switches for the clutch, and they’re look ok.
I should mention that I tried bypassing the switch (theres two, afaik -- a red one and a gray one) as well and still no luck. I even used an Ohm meter and all seems well.
Do I need to take the car to the dealer to reprogram/reflash the ECU to work with the other components? The reason I ask is because I had purchased the different modules and ECU from various places, so I am thinking if that could cause the issue?
Any ideas as to what else I could try?
Thanks in advance…
Old May 17, 2013 | 08:47 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
Yes I actually know this issue there is a part where when you push the clutch in and it needs to meet a part where it tells the car the clutch is engaged ,its a bracket beneath the clutch with a trigger and it needs to be bent back to where it triggers the clutch engagement .bend the part where it engages upward and it should work . I had this exact issue ..call me if you need help .
Old May 18, 2013 | 11:30 AM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Pretty sure you can't mix and match ECU with a different immobilizer. Hope you have the VIN from each, otherwise you cannot get the IPAS codes.
Old May 20, 2013 | 12:26 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Interesting issue. Guessing you made sure you were engaging the switches - sounds like it - but you even bypassed them.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old May 20, 2013 | 07:40 PM
javCS's Avatar
javCS is infamous around these parts
I hope is a simple repair and not the immobilizer issue. good luck
Old May 29, 2013 | 10:12 AM
GWerks's Avatar
GWerks is infamous around these parts
If you replaced the ECU you will need to get the immobilizer matched to your new ECU and possibly recode the rest of the modules.
brickdawg
Sep 11, 2015 09:08 PM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
