Cayman S stock exhaust
Old Jun 16, 2013 | 08:54 PM
Jervuno's Avatar
Jervuno is infamous around these parts
Back in 1979 I had a 3.0 litre 911 SC coupe. I found an awesome mechanic/welder who after I took the catalyst off the exhaust system he cut it open at the weld by grinding the weld then he took out the cat and welded it back together. Realizing that this is still probably considered flying below the radar, is anyone removing catalysts for better performance in their Porsches, specifically Cayman S?
Old Jun 18, 2013 | 07:02 AM
DennisP's Avatar
DennisP is infamous around these partsDennisP is infamous around these parts
I just slapped a Borla exhaust on mine and called it a day. Most bang (+-20HP) for the buck. Haven't looked back.
Old Jun 18, 2013 | 07:21 PM
ICIN235's Avatar
ICIN235 is infamous around these parts
You got any sound clips?
Old Jun 18, 2013 | 07:53 PM
DennisP's Avatar
Borla sound clips on youtube
I haven't made any of my own because there are plenty out there on youtube. Go to youtube and just type in Borla exhaust Cayman S and you'll get quite a few of them. Enjoy.
Old Jun 19, 2013 | 10:25 AM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
I imagine doing the same on the cayman would hurt performance. The cat area would be hollow and create turbulence from the larger diameter transition.
Aftermarket exhaust would remove the secondary cats and replace them with pipes.
Old Jun 19, 2013 | 10:27 AM
Jervuno's Avatar
Cayman S exhaust
From personal experience with a 3.0 litre SC, removing the cat gave me the sound I wanted and improved the performance. On a Cayman, it should be the same but I don't know if the Oxygen sensors are going to freak out and have to be bypassed or computer reset. Sure it would be easy to bolt on a Borla but then the stock exhaust is rendered useless and doesn't need to be retired.
Old Jun 19, 2013 | 10:39 AM
DennisP's Avatar
The ECU adjusts accordingly and there are absolutely no CEL's at all. This is a true CAT-BACK system so no worries there. Rather than try and resell the stock exhaust, I just left it at the installer's shop. I hope they were able to get something out of it.
2lflat4
Nov 18, 2019 05:05 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
Aug 20, 2015 02:21 PM
Aug 20, 2015 12:17 PM
Vrseis
Aug 20, 2015 07:41 AM
