psm & abs warning - wheels
Old Oct 30, 2013 | 03:55 AM
p.fisher's Avatar
p.fisher is infamous around these parts
Hi there to all on the forum.
Can anyone please tell me, can badly worn front tyres & bad tracking/wheel alignment set off the psm abs warning lights?
It seems to happen at nearly the same time & the same speed when I leave work in the evening (when its colder) & get to about 50-60 mph.
Any help or comments on this would be very appreciated.
Kind regards, Paul F
P.S. Its a 1992 Boxter 2.7 986
Old Oct 30, 2013 | 05:41 AM
phlegm's Avatar
phlegm is infamous around these parts
Your question is somewhat irrelevant at this point. I'd deal with the worn tires and bad alignment immediately, regardless of whether you suspect them as the cause.
You can then check later to see if the warnings change.
Old Oct 30, 2013 | 05:56 AM
p.fisher's Avatar
Cheers phlegm, im getting them sorted Friday morn.
I just wondered if anyone knew whether it could cause the warning or not.
Thanks, Paul F
Old Oct 30, 2013 | 12:03 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
I just read recently that someone who ran into a curb (which knocked their alignment way off) had their PSM light go off.
Old Nov 1, 2013 | 05:51 AM
p.fisher's Avatar
Okay, thanks for your replies.
I've just had the tyres & laser wheel alignment done & the front wheels were definitely out.
I'll see what happens over the weekend & let you know if the dreaded psm abs warning lights still come on!
Cheers, Paul F
DetomasoGTS74
Nov 11, 2015 09:01 AM
carwash
Sep 26, 2015 03:11 PM
pwdrhound
Aug 23, 2015 07:36 PM
thegrillboy
Cayenne 958
Aug 22, 2015 09:24 AM
JMon
Aug 21, 2015 08:20 AM
