Flywheel replacement necessary?
Old Mar 28, 2015 | 03:09 PM
Bertamus47's Avatar
Bertamus47 is infamous around these parts
Hi,
My 04 boxster s with 54k miles is in the shop for the TuneRS DOF. The mechanic said the clutch is worn and has hot spots and recommends replacing it now. He also said he can move the flywheel 5 sprockets worth which he said indicates wear and also recommends replacing. Is it usually necessary to replace the flywheel as well? Car has been driven like a porsche but never raced or autocrossed. Thanks.
Barrett
Old Mar 29, 2015 | 06:36 PM
TAch Miami's Avatar
TAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond reputeTAch Miami has a reputation beyond repute
The clutch and flywheel seem to wear together. I replaced both at the same time because my flywheel had excessive play. Now might be a good time to switch to a single mass flywheel. There might some chatter at idle but it will perk up the the car,
I found this from Pelican: "Porsche Tech Bulletin 8/02 1360 says to check the dual mass flywheel by twisting it approximately 15mm to both the left and the right, checking to make sure that it returns to its approximate starting position. If the flywheel can be twisted beyond about 15mm with no noticeable increase in spring force, or if it cannot be twisted at all then it probably needs replacement. If the flywheel checks out okay, then replace the flywheel pilot bearing and the flywheel seal."
Old Mar 30, 2015 | 11:55 AM
Bertamus47's Avatar
OK thanks for the advice. He showed me today and it did have excessive play.
Old Mar 30, 2015 | 03:48 PM
09RedGTS's Avatar
09RedGTS is infamous around these parts
"Now might be a good time to switch to a single mass flywheel. There might some chatter at idle but it will perk up the the car"
That's what id do if replacing my clutch. I'd choose a lightweight flywheel.
Old Mar 30, 2015 | 05:55 PM
pderover's Avatar
pderover is infamous around these parts
I replaced my clutch and flywheel with OEM clutch and LWFW. Aside from the rattle, I absolutely love the pull I get.
Old Mar 30, 2015 | 06:26 PM
09RedGTS's Avatar
Which LWFW did you get? Do you know the weight compared to the original? My recollection is the original was somewhere around 23-24 lbs.
Old Mar 30, 2015 | 06:46 PM
pderover's Avatar
I got the aasco flywheel 106411-11, which is about 50% lighter than OEM.
Old Apr 23, 2015 | 03:52 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Yep! Beat me to it.
To the OP: check out the website for pricing as well for future purchases.
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
