2000 Boxster; engine will not turn over
Old Oct 6, 2017 | 10:07 PM
pcsbob's Avatar
pcsbob is infamous around these parts
The car will not turn over when I turn the key. Lights, dash, radio, etc work. This occurs for several attempts, then suddenly the car starts as normal. This has happened 4 different times during the last few days
Once, it started right after i locked and then unlocked the doors with the remote. The car has a manual transmission.
Old Oct 7, 2017 | 03:44 PM
Steve997S's Avatar
Steve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond reputeSteve997S has a reputation beyond repute
How old is the battery and is it correct for the car?
Old Oct 7, 2017 | 08:40 PM
pcsbob's Avatar
correct battery, 3 years old
Old Oct 8, 2017 | 08:12 AM
jg_atl's Avatar
jg_atl is infamous around these parts
What year is your car? Could be ignition switch (known weak part) or perhaps clutch interlock switch. It easy to jumper the clutch switch to take it out of the equation.
Old Oct 8, 2017 | 08:32 AM
pcsbob's Avatar
the car is a 2000, the ignition switch was replaced 2 years ago, I have not yet started testing things. I will start with the clutch interlock
Thank you
Old Oct 8, 2017 | 08:41 AM
jg_atl's Avatar
Even though the ignition switch has been replaced, it could still be the culprit. The clutch interlock is an easy place to start.
Old Oct 8, 2017 | 09:04 AM
pcsbob's Avatar
Thank you. I will begin with the clutch
Josh/AWE
20
Apr 22, 2020 03:46 PM
hhubard
Feb 18, 2017 12:44 PM
Stryke
Dec 24, 2003 10:52 AM
