Macan MF-wheel in 987.2 sport chrono
So i got hold of a macan wheel, and i've fitted it and used piwis to enable MF-wheel under steering column and pcm.
But the buttons arent working and its giving a fault message "Multi-function steering wheel timeout (no signal)
The steering wheel has both the mf harness and control unit inside, is there anything else im missing? or is it not possible to enable this?
There is a thread on Planet-9 talks about same thing for a 981, you'll need an adapter to make it work.
http://www.planet-9.com/981-cayman-a...n+wheel+cayman
Good luck and let us know how it goes!
That looks spot on... sigh... starting to get expensive this wheel conversion... i even got the wheel with heat.. so theres another 100 bucks
But thanks, never heard of this adapter!
Macan
12-01-2015 08:54 AM
GMP Performance
Macan
08-03-2015 03:18 PM
