Bad immobile question
Old Oct 18, 2018 | 08:49 PM
shadow993's Avatar
shadow993 is infamous around these parts
If I have a bad immobilized from getting wet will it still turn over?
My car got water in it, but not a lot in the floor after I removed the seat. It drove fine for a few days, and now will not start. Turns over all car functions work properly.
I do get a high pitch noise from the throttle body, so that may be the issue. It does open and close with the pedal though.
Thanks in advance
Old Oct 18, 2018 | 10:23 PM
shadow993's Avatar
I opened up the module and it's clean with zero signs of water. The fuse is still good too.
Throttle body??
Old Oct 19, 2018 | 07:23 AM
jg_atl's Avatar
jg_atl is infamous around these parts
More likely crank position sensor, if it is not the immobilizer. I believe car will turn over if immobilizer is bad - it just will not start.
Old Oct 19, 2018 | 08:23 AM
shadow993's Avatar
Fuel pump relay fault showed up.... fingers crossed.
Cayenne 955/957
36
Jan 8, 2008 08:42 PM
grussell
Dec 27, 2006 09:26 PM
Mussel Kar
Sep 20, 2006 02:31 PM
