PCM 4.0 Back up Camera activation.
Old Jun 13, 2023 | 06:16 AM
vartech's Avatar
vartech is infamous around these parts
Backup Camera Error U111100 Communication error after OEM retrofit.
I retrofitted a OEM 95B.980.551.L using a wiring harness from Aliexpress I connected from the camera ther following Can High to connector E on PCM pin 6 Can low to pin 12. Camera to Connector B pin 6 and 12. Ground to trunk and power to fuse box. PIWIS sees camera module and it shows when I place car in reverse. it shows power voltage at 14.2. PIWIS states camera needs calibration only fault on module. I read on a different forum that should not stop camera from working. On the PCM I get the communication error in PIWIS under faults. Nothing changes on PCM when I put car in reverse. Is my Camera bad? is there something I am missing? I did add back up camera to PCM in PIWIS
ScottDy
Aug 30, 2019 09:30 PM
05997S
Jul 5, 2012 04:51 PM
GoodSpeed
Cayenne 955/957
Mar 29, 2009 08:10 AM
