Base Cayman with PASM or Cayman S non PASM?
Old Jul 8, 2007 | 12:46 PM
AP2Suzuka's Avatar
AP2Suzuka is just really niceAP2Suzuka is just really niceAP2Suzuka is just really niceAP2Suzuka is just really nice
Originally Posted by MSCaymanS
I have a CaymanS w/PASM and at the track it's night and day. The car handles so much flatter and the only reason would go to an aftermarket suspension is if you wanted to adjust the camber, toe in, etc.....I only do 4-5 track days a year if that so the PASM is sufficient. Only thing it needs it a LSD and some sway bars.
That's odd; so if you have PASM on the car you can't adjust your alignment settings
Old Jul 8, 2007 | 02:45 PM
MSCaymanS's Avatar
MSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud ofMSCaymanS has much to be proud of
You can but not as much as you can with aftermarket suspension and camber plates.
Old Jul 8, 2007 | 02:56 PM
AP2Suzuka's Avatar
Ahhh, I see Just like the S2000's you can only max out the camber to a certain point then you have to get some roll center adjusters:
http://maxrev.net/index.php?location=RCAreview.htm
Old Jul 10, 2007 | 07:41 AM
pilone's Avatar
pilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nice
In anycase if you are a good driver you won't need sport settings...just get the S...the hp are more important!
Old Jul 10, 2007 | 08:24 AM
Karrera4's Avatar
Karrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to all
I was going back and forth on PASM too. I ended up getting it and love it because my Cayman S is my daily driver. It rides great! I do not think I will ever use sport mode unless Im tracking.
Old Jul 12, 2007 | 11:25 AM
BB987's Avatar
BB987 is infamous around these parts
Go for a cayman S with PASM..it does help me decrease AX time..
brickdawg
Sep 11, 2015 09:08 PM
carsnob
Sep 8, 2015 04:10 PM
arhim22
Sep 7, 2015 08:49 PM
shiftmechanism
Sep 4, 2015 04:14 PM
