Blown Cayman
Old Aug 11, 2007 | 09:42 PM
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
The super charger is from Rotrex.It is runing twin intercoolers.This is on a stock engine.The ECU has been highly modified with different rev limeter set for each gear.MAX speed 195MPH.It's a quick as a 997 turbo
Old Aug 11, 2007 | 09:52 PM
Neil@Orton's Avatar
This is a production kit.This one is the first one off to a P dealer in FL.
Old Aug 11, 2007 | 10:06 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
so how do you run that much boost without lowering the compression?
where are the intercoolers located?
who did the ecu programming?
is the supercharger a roots style or centrifugal?
did you upgrade the fuel injectors?
Old Aug 11, 2007 | 10:17 PM
Neil@Orton's Avatar
Many months of testing has gone into this kit.Yes the injectors are changed as well as many other parts including an inlet manifold that has intergrated twin intercoolers.The programming has been done by my programmer which took 4 weeks on a engine dyno.The intake temp is only 10 deg higher than the out side air temp .the blower is centrifugal.
Old Aug 11, 2007 | 10:26 PM
so how do you run boost that high without lowering the compression? i think RUF is running 8 or 9 psi and they lower the compression. my evo kit runs around 5-6 psi and is making around 510 hp on stock compression.
Old Aug 11, 2007 | 11:42 PM
iLLM3's Avatar
God damn that car looks and sounds great, more info
Old Aug 11, 2007 | 11:44 PM
Neil@Orton's Avatar
Ruf run 11 psi
Old Aug 12, 2007 | 09:52 AM
Ruf run 11 psi
Ruf run 11 psi
My bad. That's even more boost than I thought. How do you run such high boost on essentially a 3.4 996 engine without lowering the compression? Is it safe to run the boost that high? I would think with that much boost and stock compression you would be seeing much higher hp numbers.
I checked your site and there weren't a lot of details. Looks like a nice package. Very similar to the RUF design with the way you did the intercoolers in the intake manifolds.
Old Aug 12, 2007 | 05:47 PM
Neil@Orton's Avatar
The latest version is much different from the one in the post.There is not problem with this amount of boost because of the twin intercoolers and the air temp after the intercoolers.
Wait till you see the next version. We are soon to be building one with 700hp with a seqential gearbox
Old Aug 12, 2007 | 06:09 PM
MiniDHinkle's Avatar
Dang, Neil. Seq. Gearbox! Thats crazy.
Old Aug 12, 2007 | 06:19 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
That kit looks awesome. Is the sequential gearbox a dog clutch or is the shifter just revised so itll be a sequential?
Neil@Orton's Avatar
Never mind the gearbox.4Ltr and it will run @ 1'4 bar boost
Old Aug 12, 2007 | 06:21 PM
Neil@Orton's Avatar
Full Seqenstial with padle shift.
Old Aug 12, 2007 | 06:24 PM
Neil@Orton's Avatar
The kit looks very different now.
http://www.caymanclub.net/attachment...charged-sc.jpg
Old Aug 13, 2007 | 09:32 PM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
Originally Posted by K-Man S
Wow that's really clever, did it take you long to come up with that? Hey don't look now but I just went to a website you don't visit and called you names. Wait, I think I hear your mom calling...
Oh brother, you are barking up the wrong tree here. I probably should not have called you a tool even though you don't post here and even if its true but you have to be kidding me now.
