New Brembo Brake Kit for Cayman
Old Aug 13, 2007 | 06:59 PM
vividracing's Avatar
Brembo just released a new 15" 4piston kit for the Porsche Cayman owners. Targeted towards the most aggressive drivers needing the best stopping, this new Brembo kit will out brake anything on the road or track. The Brembo kit features a 2pc floating rotor. Each Brembo kit includes steel braided brake lines, high performance street pads, and caliper components for a direct bolt on. After wheels are required. 19" will definitely fit. The kit comes in black, red, silver, or yellow. Rotors can be had in slotted or drilled. For track racers we recommend slotted.
Checkout our review featured in Modified L&E Magazine on the Brembo brake kit here -
http://www.myvividracing.com/showthread.php?t=20896
PM or Email for special 6speed Pricing.
Old Aug 23, 2007 | 12:29 AM
K MEN S's Avatar
K MEN S is infamous around these parts
is 4 pistons the maximum you can put in a cayman?
what about 6 pistons?
Old Aug 23, 2007 | 09:42 AM
4piston is all Brembo has. If you want to do larger piston, check out Rotora. How many pistons is not as important as piston bore, size, surface area, rotor diameter and more. A car like the Cayman only needs the 4piston. With a 15 inch disk, you will have no PROBLEM stopping.
Old Aug 23, 2007 | 11:12 AM
Frissen's Avatar
Frissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud ofFrissen has much to be proud of
PCCB's I believe are 6 piston front... readily available for Cayman...
Moving into the offered Brembo front is ok and all but wonder about the rear... what can be done to upgrade accordingly in the rear?
I love upgrades and solutions as long as they bring balance... leaving the stock rear is not IMO balanced specially if you are running a 2.7 that carries smaller brakes than the 3.4
Old Aug 23, 2007 | 12:28 PM
With the help of Gary at Race Technologies -
"PCCB's are an OEM option and offer OEM type performance.
(better than many other options, but they still have issues) We've had people remove the PCCB's in favor of a Gran Turismo kit.
PCCB's have been known to have many problems on the track and in track like scenarios. The first generation was the worst, and I believe they are already on their 2nd or 3rd generation of discs. I am still not comfortable with their performance off of public roads. Not to mention that the replacement discs, if damaged, are thousands of dollars each.
The Brembo Gran Turismo system, even as front only, does provide optimum brake bias. The goal with this system was not to add tons of extra braking force. The OEM braking system is sufficient to brake beyond the limits of the tires. Our goal was to increase thermal capacity to be able to repeatedly brake to the limits of the tires with no fade related issues.
While doing this, we've added a two piece disc for unsprung and rotation weight savings, and the full floating ability to prevent disc distortion and allow it to seek a true centerline for even pad and rotor wear. The greatest benefit is that the newer caliper offers better modulation, pedal feel and control.
The only advantage of PCCB is the extremely lightweight disc. The caliper is a brick, pad selection is non-existent, and the cost of replacement parts is ridiculous. The cost of the two upgrades is very similar, and the Gran Turismo kit suites the needs of an enthusiast much much better."
Old Aug 23, 2007 | 05:35 PM
OC Pcar's Avatar
OC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant future
what are the stockers on a 2.7 "S"--14"? what's the brake distribution between front and rear stock and after upgrade if any change...
Old Aug 23, 2007 | 08:55 PM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
This is what would be important to me. I really dig how light teh PCCB's are but have yet to hear anyone tell me anything other than they are either the same or only slightly better than stock binders. I think the money for PCCB's could be better spent.
Old Aug 29, 2007 | 02:49 AM
K MEN S's Avatar
may i know what are the basic color of those calipers? yellow, black , silver?
Old Aug 29, 2007 | 09:42 AM
Black red yellow silver
ECS Tuning - VW
Aug 20, 2015 03:07 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:49 PM
