what filter are you running?
Old Sep 9, 2007 | 09:17 AM
JCS's Avatar
JCS
JCS is infamous around these parts
Originally Posted by APCayman
Alright I took your advice and did some research. .....but I did not verify that it is less effective in varying temperatures or in rainy conditions.
K&N , the manufacturer of the oiled filter in question has done it for you.
And I give them credit for being honest enough to put a big WARNING
on them ....
quote from K&N air intake :
".....is a performance product that can be used safely during MILD WEATHER CONDITIONS .
During HARSH and INCLEMENT conditions (rain, snow etc.) you MUST return your vehicle
to stock OEM airbox and intake tract configuration .
Failure to follow these instructions WILL void your warranty "
( the capitals and emphasis are by me )
I don't have a problem understanding the above .
Old Sep 10, 2007 | 10:01 AM
blinkwatt's Avatar
blinkwatt is infamous around these parts
on them ....
Where is this warning sticker/label that you speak of?
Old Sep 10, 2007 | 04:12 PM
JCS's Avatar
JCS
The quote is directly from the K&N Installation/Warranty booklet .
Old Sep 10, 2007 | 05:22 PM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
Mods can you lock this one up as well, someone here has an agenda.
Old Sep 13, 2007 | 12:50 AM
adam89911's Avatar
adam89911 is infamous around these parts
k&n is the way to go.
Old Sep 14, 2007 | 12:51 AM
tri's Avatar
tri
tri is infamous around these parts
vivid racing has k&n for dirty cheap
Old Sep 21, 2007 | 09:54 PM
dyazdani's Avatar
dyazdani is infamous around these parts
As the spaces between the fibers get smaller due to the trapped particles,
ever smaller particles get caught .
Hence , the efficiency of the filter gets better, the smaller the
passages become.
This is actually a true behavior of filtration processes. The particles pass through two "filters" each with different resistances. One filter is the actual fiber part, the other filter is made up of the previously captured particles. This is normally called the filter cake if you read engineering texts.
So as not to wander further off topic... I use a Mahle filter as well. Every autoforum I read no matter the type of vehicle, has a crowd that detests K&N type filters. Plenty of people use K&N filters and apparently have no issues. If you want to try one I say go for it. I choose not to for cost more than anything.
Old Oct 31, 2007 | 09:40 AM
narbeh's Avatar
narbeh is infamous around these parts
i just realized that these posts were still going on. so whats the final verdict guys? post what brand filter do you use? (not a CAI, just factory replacement). thanks
Old Nov 2, 2007 | 09:20 AM
humara's Avatar
humara is infamous around these parts
i remember seeing some crazy KN booth at the LA auto show with a machine set up to disprove the "oil on the maf" internet stories that were popping up. don't know if i believe K&N or not, but at least they aren't taking this lightly.
The machine basically had a well oiled filter inside and the machine was constantly blowing high pressure air on it. the maf was clean the entire time.
very elaborate attempt to prove a point.
shifter_
Sep 8, 2015 12:07 PM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
