:: ECS Tuning :: 955 S Rear Drive Shaft Support Bearing
Old Jun 5, 2014 | 10:24 AM
ECS Tuning - Porsche's Avatar
Unusual thumping sounds originating at the center console of your 955 Cayenne are usually the consequence of a worn or failing rear driveshaft support bearing.
The bearing sits in a bracket and secures the driveshaft to the chassis of the vehicle, supporting the very heavy prop shaft on its way to the differential. Unfortunately, when this part fails, Porsche only provides a single costly solution - the replacement of the entire driveshaft assembly.
ECS offers a more sensible repair solution - a replacement Rear Driveshaft Center Support Bearing by MTC.
ID:	382832   Click image for larger version
Old Jun 5, 2014 | 11:42 AM
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
mmm.. what make of this? if chinese wont last long...
next thing is to change this only part you need to disassemble propeller shaft, and forge-roll it back properly that is very hard to do. more, will be vibration after this procedure, so bolts at bearing need to be tighted up in place only with spinin up prop shaft...
ID:	382851   Click image for larger version
ID:	382852   Click image for larger version
ID:	382854   Click image for larger version
ID:	382855   Click image for larger version
Old Jun 5, 2014 | 12:23 PM
The quality of this bearing is very good. Installation is much more involved than a simple shaft replacement, so we recommend taking the new bearing along with your shaft to a driveshaft shop for installation and balancing. The cost to install and balance is usually still far less expensive than buying a new driveshaft.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
