Fog Lamps Error Out?
yea thats what i love about mine they are plug and play. I ordered the adapter to cancel out the error codes, i will post results when I get them.
I used to sell HID kits and just to let you know the correct resistor needed is a 50W 6ohm resistor. Just splice the two wires between the positive and negative wires from the HID harness. So easy!! You need one resistor for each side. They can be found all over ebay just search "HID resistor" and you will get a bunch of results.
Another thing you can do is to buy some 25V 10000uF capacitors from radioshack for a few bucks and wire them inline to your harness going into the ballast. These create no heat really and often fix a lot of HID issues.
