Engine stall
Old Jul 25, 2008 | 05:23 PM
Enilder's Avatar
Enilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond reputeEnilder has a reputation beyond repute
Engine stall
Hey all,
I have 06 Cayenne S and VERY rarely (handful times past 2 years) when I go from reverse to neutral, engine stalls.
I took it to a dealer but they told me they cant do anything because it worked fine when they checked it.
Should I just cross my fingers and hopefully nothing goes wrong later on?
Anyone had this issue?
Old Jul 25, 2008 | 05:33 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
I know I shouldn't even comment if I cannot help with an answer, but I have felt that when I reverse, and I go to shift into drive, before the car comes to a complete stop, a slight hesitation in the car, almost as if it felt like it might have wanted to stall.......
But crossing fingers, no stalls yet....maybe you should come to a complete stop before shifting out of reverse . if you are, then no clue.
Old Jul 25, 2008 | 06:00 PM
Enilder's Avatar
actually, i went from reverse to neutral and waited about couple seconds AFTER car came to a stop.
then i went from neutral to drive and tried to go but i realized that engine stalled.
it has happened less than 5 times but just wondering...thanks for posting though
Old Jul 25, 2008 | 09:25 PM
mlc.design's Avatar
mlc.design is infamous around these parts
any updates or recalls on the S's?
Old Jul 26, 2008 | 08:54 AM
Enilder's Avatar
nope. the tech couldnt make it stall and according to the service manager, they have to "see" in order to do anything about it.
Old Jul 26, 2008 | 09:31 AM
wilfred's Avatar
wilfred is infamous around these parts
The first thing that comes to my mind is bad gas. But because it is a Cayenne, I would say it's cracked coils. Seems to be very common problem for all kinds of engine related issues. If your car is still under warranty, have your dealer check them out and make sure they replace all 8. If not, it's not expensive if you are a DIYer.
http://e-partssales.com/Merchant2/me...y_Code=955main
Jul 29, 2019 11:13 AM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
NTIMD8
Sep 1, 2015 09:58 AM
vr6tee
Aug 29, 2015 03:52 AM
