Got my new 09 Cayenne with enhanced PCM3 !
Sweet, so it sounds like I just need to order the ipod connection kit and my pcm3 has the ipod control software built-in.
Should I call nav-tv to arrange an order for the ipod kits?
Hi Nav-TV, you mentioned that you have limited stock of iPod / USB / AUX kits available; I have a 2009 Cayenne GTS with PCM3 without iPod / USB / AUX option. How can I get one?
Thanks,
Thanks,
Thanks,
Gregory
P.S. - Can't PM yet. I got less than 15 posts. Can you possibly email me at hakdkim@hotmail.com
In previous years, the PCM2 had 2 variants: with internal amplifier and without (the latter requires a BOSE Amp.)
My 2009 PCM3 does not have an internal amp and requires a DIFFERENT BOSE amplifier then in previous years.
I do not know yet if a non-bose 2009 vehicles has a PCM3 with a built-in amplifier, we'll have to wait and see (or hear from somebody on this forum).
If there will be a PCM3 version with an internal amplifier, your retrofit will be rather easy. I may even consider manufacturing such harnesses as all that's required is an adapter cable with the "old" DIN female plugs on one end and the new FAKRA male plugs on the other end.
it's a small harness that will be added to your existing harness, and the whole job should take 10 minutes or so, without of course running any GPS antenna cables or other accessories such as Bluetooth microphone, iPod / USB / AUX center console retrofit kit etc.
BR / Moni
BR / Moni
Hello Nav-Tv.
Can you help me to retrofiting my ´06 Cayenne S with CDR-23 no Bose to a PCM 3 with amp? I already hace the new head unit and the Bose amp, but i need the wiring harnesses from PCM to amp, from amp to speakers and MOST conections and bridge, anyway I need everything to connect the system. Every help will be wellcome to solve my situation.
Thanks.
