Brake Workshop Message?
Old Nov 6, 2008 | 08:39 AM
04CTT's Avatar
04CTT is infamous around these parts
I guess I am in need of some new pads but I was just curious before I bought the pads and rotors if there is any special tools needed for this. Also do the sensor for the brake pads have to be replaced? I am just used to most brake jobs like corvettes so I just wanted to make sure I have everything I need before I start thanks in advance. Also any ideas on brake pads aftermarket or OEM? Thanks for your help.
Jared
Old Nov 7, 2008 | 09:44 AM
liuxiaoyu's Avatar
liuxiaoyu is infamous around these parts
the sensor need to be replaced
Old Nov 7, 2008 | 10:43 AM
cayenned's Avatar
cayenned has a spectacular aura aboutcayenned has a spectacular aura about
Do a search on brake pads, there are plenty of threads on it.
I went with Hawk Ceramic Pads, virtually dustless compared to the OEM pads. You need to replace the sensors as well(got them form Suncoast)
good luck.
Old Nov 7, 2008 | 11:21 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
No special tools although a pair of needle nose pliers is always handy when pulling pins, the condition of your hardware may also cause those pins be be "rusted" in place if they were driven hard and put away wet.
I get my parts here:LINK
Sensors are set up to break once removed so yes, they need to be replaced with pads. I would also suggest replacing those old hardward kits and mounting bolts while you're there.
-Eli
Old Nov 7, 2008 | 03:56 PM
medtech's Avatar
medtech is infamous around these parts
Check the DIY posts on Renntech.
Old Nov 9, 2008 | 05:10 PM
tonga3's Avatar
tonga3 is infamous around these parts
I have also heard that Hawk Ceramic are the way to go to avoid dust.
Old Nov 13, 2008 | 09:52 PM
So how did things turn out? Let me know if you have any questions I can help with....
Also just for the record, PM me if you need more info on removing the calipers, you'll need a special tool for the job.....
-Eli
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
Fester
Sep 8, 2015 09:35 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
